#360
Hi, will try.
sub question: what shoud one choose, when the dvd blank is inserted and a two options dialog opens? What is the difference from cd dvd or usb.
Does that mean if you check usb, then all could be used to delete and copy as in pendrive.
This is a problem only with win 7 and more recent version. Whatever we select, it auto changes to udf format, which again poses problem when reading with xp machines , earlier versions.
