#390
Your Mother's factory image will not work on your laptop.
The error messages you're getting indicate that you may have a dead hard drive.
To verify this, you can create bootable "SeaTools for DOS" media to boot from and run on your laptop.
https://www.seagate.com/support/down...ls-dos-master/
If the hard drive checks out ok, then create a startup repair disc on your Mother's laptop, boot from it on your laptop, and run a startup repair.
System Repair Disc - Create - Windows 7 Help Forums
Startup Repair - Windows 7 Help Forums
