Page 40 of 43 FirstFirst ... 303839404142 ... LastLast
  1. Posts : 72,051
       #390
    Your Mother's factory image will not work on your laptop.
    The error messages you're getting indicate that you may have a dead hard drive.
    To verify this, you can create bootable "SeaTools for DOS" media to boot from and run on your laptop.
    https://www.seagate.com/support/down...ls-dos-master/
    If the hard drive checks out ok, then create a startup repair disc on your Mother's laptop, boot from it on your laptop, and run a startup repair.
    System Repair Disc - Create - Windows 7 Help Forums
    Startup Repair - Windows 7 Help Forums
  2. Posts : 19
    Windows 7 Ultimate 64/32 bit
       #391
    That's a great news! I'll go ahead and try to download SEATOOLS for DOS then once the Hard Drive is not deadI can go ahead and create a System Repair Disc so I can move forward with the BOOTMGR is Missing.
  3. Posts : 19
       #392
    Sir. Brink, Why my SEAGATE is not running? 😔
    Attached Thumbnails Attached Thumbnails USB Windows 7 Installation Key Drive - Create-img_1632.jpg
  4. Posts : 72,051
       #393
    Just to confirm, did you follow all the step at Seagate below to create the bootable DVD or USB, and boot from it?
  5. Posts : 19
       #394
    Yes, I was able to follow the steps. What I did is I extract the SEAGATE files to my boot USB using 7-Zip 64bit (should I change it to 32bit?) then changed the ima to img, by the way I just bought a new B.CD for the System Repair Disc just in case..
    1 more thing I remember my RUFUS file system is Fat32 and create using DOS
  6. Posts : 72,051
       #395
    That wouldn't work to make it bootable.
    Instead you must burn the ISO to the USB using the steps below instead.
    How to burn an .iso image onto a CD/DVD-ROM
  7. Posts : 19
       #396
    I agree with you. Actually a few mins ago I was able to read some blog and 3rd parties will not work with SEAGATE it should be a normal USB drive when you extract the files, then you cannot copy "BURN" image of an ISO to CD.
  8. Posts : 72,051
       #397
    I like using Rufus to create a bootable USB with an ISO.
    Rufus - Create bootable USB drives the easy way
  9. Posts : 19
       #398
    Agreed! if you will see the comparison from other tools/apps rufus is the best and fastest of them all for ISOs. I think I get it, I'll just use the B.CD for SEAGATE and follow all the steps. I'll keep you updated Sir. Brink. THANK YOU SO MUCH! :)
  10. Posts : 19
       #399
    Hi, Sir. Brink. I was able to run SEAGATE and do a Long Test Right away and the result is Passed, Why it only show 1 passed? After I removed the CD and reboot my computer I'm still receiving BOOT MGR is missing. I forgot to create a system repair disc. Sorry..
