Page 41 of 43 FirstFirst ... 313940414243 LastLast
  1. Posts : 72,051
       #400
    No problem. See if you may be able to run a Startup Repair with a System Repair disc.
  2. Posts : 19
    Windows 7 Ultimate 64/32 bit
       #401
    Hi, Sir. Brink. Thank you again, I wasn't able to create a system repair disc because I was not in the office of my Mom. So I just did the Ult Boot Usb and the good news here is after I passed HuSEAGATE now I am curently in windows 7 Install, I checked system recovery options for sysyem recovery tool and image but both are blank so i checked "Load Drivers" and I saw my C: " System Reserved" its empty so I checked properties of my C: and my files are there, so what I did next is run 4x Startup Repair, send the problem to windows, then I checked view diagnostoc and repair details, it was able to fixed everything besides Bootmgr is missing or corrupt. I restarted the computer. Should I Load Driver and compressed my C: or go to Tools tab then "Error Checking" check now and fix? What to do next?
  3. Posts : 72,051
       #402
    Next would be to try these troubleshooting steps.
    Troubleshooting Windows 7 Failure to Boot - Windows 7 Help Forums
  4. Posts : 19
       #403
    Hi, Sir. Brink, By the way I also checked cmd and tried the 4 bootrec for repairs and it showing that it was sucessfully fixed and I tried also Sfc but It doesn't allow me to scan it. Still encountering bootmgr is missing or corrupt, I'll go ahead and work on the "Troubleshooting Windows 7 Failure to Boot" then I will let you know. Thank you so much. 😊
  5. Posts : 19
       #404
    Sir. Bink, I just followed the steps but I can't fixed boot mgr is missing or corrupt, I'm urrently stucked on Step 1 and 2 and the chkdsk /f is not working..
  6. Posts : 72,051
       #405
    You could try doing a factory recovery. If it's the same Toshiba in your specs, you can get recovery media from Toshiba at the link below.
    Repair & Parts Support | Toshiba
    If you're not able to install to the drive, then the drive may actually be dead.
  7. Posts : 19
       #406
    Awesome! Thank you so much for that sir. Brink. I'm so sorry if it takes 2 days before I was able to reply regarding to my situation but I just want to let you know that my drive is not DEAD. Actually I was searching for a resolution for 2 days so I can fix this issue with my computer. I followed your instructions and encountered some problems, But what I did is I clean reinstall my computer because my case is so complicated because of my tools that got infected, malware, virus, adware, rootkits, trojan, worm, fake intels, fake mc cafee, fake adobe, fake flash player, Home Group virus, even my toshiba tools got infected, and etc... But my case right now is much better I just followed different post regarding to my issue so I can move forward, but right now I encountered an issue with my internet connection but I was able to resolved it. I just need time to install the tools of my computer and update everything manually.Thank you so much again for your help Sir. Brink!
  8. Posts : 72,051
       #407
    That's great news Steven. I'm happy to hear that all is well again.
  9. Posts : 19
       #408
    Yes Sir. Brink thank you so much for all your help again!! I really appreciated your advise, especially your time and effort, I really learned a lot because of those experience that I get from you, staffs, and members. Even the BOOTMGR and DISK PARTITIONS, Now I already know what do just in case I encountered those problems again. :cheers:
  10. Posts : 182
    Win 7 x64.Win 10
       #409
    Macrium rescue dsk
    I went to the area here that has a very long list on how to create a MR Rescue dsk, but to say the least, it was so variable and some went back 5 years, so one doesn't even no if its still apply. My MR vers is 6.01..if that is any help to mention. How do i know which suggestion to choose? I have a MR Win 7 image file that I would like to restore.
