#90
Sounds like it can be more customizable, but just a bit more involved.
Thanks for this guide, but I'm having a bit of trouble. I have the files that I extracted from my original x86 ISO, but not the ISO itself, and I believe that is the reason why.
When I load my x64 ISO, it automatically brings up the autorun/view files window, but the ISO I made with the x86 files, doesn't, so information has been lost I would assume?, when I copied the x86 files from the disk I had made, when what I should have done is make a copy, or just bloody kept the original ISO in the first place.
Do I need to download the x86 ISO again, or can I do something whilst making an ISO to make it recognise it as bootable? I'd stick with with 64, but it's going on an Acer netbook with an Atom.
You can make a bootable .iso from the x86 installation files very easily with the free vlite - saves downloading it again:
Bootable ISO - Create from Installation Files
Looks like you are missing a few files.
Have a look in the sources folder - see if you can the setup.exe in there.
I now have a bootable x86 ISO, so the issue isn't with that, I don't think, because when I load it up in MagicISO, it gives me the autorun window, but when I burn it to my Kingston 4GB card, it doesn't.
Right, on my sisters Dell with XP, it boots from the card after restarting, i.e proceeds to load Windows 7 files to do a clean install, so I guess it must work to a degree, however on my system, with bios settings changed, it gives me a black screen with the option to load 7 normally, or run the memory diagnostic tool, but no option to do a fresh install.
