Page 11 of 43 FirstFirst ... 91011121321 ... LastLast
  1. Posts : 529
    windows 8.1 Pro x64
       #100
    so this guide is to allow you to install windows 7 of a usb stick? if so thats very good, smaller and faster than a dvd.
  2. Posts : 72,043
       #101
    Hello Chrysalis,
    Yes, it allows you to be able to install Windows 7 on your computer from a faster USB stick instead of a slower DVD. :)
  3. Posts : 3
    Win7
       #102
    New Win7 Flash Drive Builder
    After struggling with making bootable Win7 flash drives, I though you all might be interested in an app I was beta testing a couple of weeks back, and greatly simplifies the steps of building a bootable Win7 USB flash drive. They just released the final version...freeware! It also supports building from Windows XP.
    BootSage Flash Builder
    Enjoy
  4. Posts : 8
    hey man very nice and easy tweakins you got there but one question im going to use UltraISO method and can i still put some other files through my USB even if theres a Windows7.iso in there as bootle W7 installer?
    my USB is 16GB around 4GB total of my Windows 7 ISO although there's still too much free space left overs you know
  5. Posts : 72,043
       #104
    Hello Coco,
    Yes, you will still be able to save more files as normal on the USB afterwards. :)
  6. Posts : 8
    Brink said:
    Hello Coco,
    thanks for feedbacks i really like you post its really useful
  7. Posts : 72,043
       #106
    You're most welcome. :)
  8. Posts : 8
    hello brink i have some question if you dont mind..can i use both Windows 7 and XP boot in my Flash Disk? i was thinking to do this ,
    1. i have existing Windows 7 in my flash drive im going to move and create a new folder for Windows 7 as temporary to avoid conflict from new boot
    2.im going to create a new boot of XP to my flash drive
    so if im gonna use my Windows 7 boot i just gonna create new folder for XP and i'll bring Windows 7 at the first place like before, will this possible work? actually i can try it but i dont wanna get messed up if this method was wrong cause creating a bootable of Windows 7 (5 GB) to my flash drive will takes around 5-6 hours..
    (sorry for my bad english)
    EDIT:
    oh yes we can't write cause it says everything inside the flash disk will be deleted, i created a backup files to the desktop i'll soon paste it back tp flash drive after the writing and let see if this works..
  9. Posts : 72,043
       #108
    Hello Coco,
    Sorry, but you can't have a dual installation USB flash drive like that as far as I am aware of. If you want a XP one, it will need to be on a separate USB flash drive, or format that one and create one for XP only on it.
  10. Posts : 4
    Windows 7 RC
       #109
    Still can't do it...
    Hi there,
    I'm still having issues on creating a bootable usb.
    I'm trying to install a Business version (Student version downloaded from MS Academic Alliance), I get throught the cleaning just fine, but when I try to copy the files from a mounted ISO image to the USB i keep getting an error saying "Invalid MS-DOS function" and the copy fails.
    I have also tried to burn the image and install it from a disk, but the installer doesn't recognize my DVD drive, no matter how it's setup (IDE/AHCI).
    So please I ask for help.
