#20
recycle bin
Thank You Very much!!! That's one thing less that will annoy me! Bill
I know this opic is quite done, but I wanted to add my own thanks. The ,0 worked for me too.
I thank you and my girlfriend does as well; I get very unpleasant when my computers don't do as I say.
Thanks for this!!! It fixed the problem with my icon not refreshing. For some reason the ,0 was missing on all of them.
I found a better fix for this that doesn't need you to edit the registry, all you need to do is open the theme file with notepad and add ,0 after the icon name and then save it, then when you apply your theme it will add that to the registry as well and solve the problem, this way works better if you have multiple themes that have different icons and saves you having to do the fix every time you change your theme.
This path will only work with your Icons. Besides the fix is just adding ",0" for every entry in the registry.
I suggest you just change the icons with the Windows GUI. Then run regedit.exe go to
HKEY_CURRENT_USER/Software/Microsoft/Windows/CurrentVersion/Explorer/CLSID/{645FF040-5081-101B-9F08-00AA002F954E}/Default Icon
And by each entry add at the end ",0" like this:
"D:\Projects\Icons\Chinese Box Recycle Bin\Neuromancer Chinese Box Empty.ico,0"
that is the path to your icon with added ",0"
That fixes the problem and lets you keep the original place of the icons you use.
Just don't move them :)
P.S. If you save the Theme after this the register change will be saved as well. If you edit the theme file and change the register there. Then apply the theme it will be the same as if you changed the register. The point is when you fixed the register - save the theme.
Hey man, I tried your method and it worked like a charm, so I made an account just to say a big thankyou!!!!
Does this apply to all type of icons? Becoz when i try to change one of my folder's icon, It doesn't change unless i refresh.
Hello Engkhsky, and welcome to Seven Forums.
Sorry, but no. This tutorial is only for the Recycle Bin.
If you like, you can create a new thread in the "General Discussion" area to see if a solution for your issue may be found.
