Very cool Brink!
I soon will try it ;-)
Thanks!
zx81
Very cool Brink!
Thanks!
zx81
What he meant was what I just tried :)
When I attached the VHD, (see attachment), there is a Read Only option (I circled it in red). I wanted to be sure that I could still use the system image as a system image if I ever had to restore my system. But when I do, it mounts as an unformatted drive. I had to unmount it, make sure Read Only was not checked, then it simply worked.
Do you (or anyone) know/tested that a system image does infact work after mounting it as a VHD? (Not making any changes to it, of course.) Because I think I remember, while doing some research on Win 7 before I got it, that if you messed with the windows system restore image file, it could never again be used as a system restore...
[IMG]file:///C:/Users/DEFAUL%7E1.PUG/AppData/Local/Temp/moz-screenshot.jpg[/IMG]
Hello Sabre,
I have not tested it, but as long as changes were not made to the VHD, it should still be able to be used to restore the image with.
even though the fix described above didn't work for me, it pointed me in the right direction until I found a solution for why my Win7 repair function couldn't find any image files. Here's what didn't work after my SSD boot disk failed and I re-installed Win7-64 bits, giving it the same computer name that I had originally chosen (win7-64):
* Opening the image files and copying them to C:\ - many open files prevented copying, as noted by someone in the thread
* booting up to WinXP and copying the files; some still wouldn't copy - with error message of "access not permitted" or some such.
* booting up in Linux (Ubuntu 9.04) and copying the files. All files copied to my Win7 boot partition, but still, after booting, my Win7-64 wouldn't open any of the dozens of programs that I had installed during the 4 months since I started using it. Hundreds of hours of my time down the drain? No . . .
After copying the files to C:\, I found that the repair function of the Win7 installation disk suddenly was able to see my images. I chose the latest and, after waiting for it to copy 91,000+ files, I'm now using that OS to write this. Joy!
I still have no idea why it couldn't see those image files previously. No matter - now I'm going to test the free BartPE image creation/recovery program that I've used with such success for several years with WinXP; I presume it will be more reliable than this questionable M$ backup system.
This is great. Exactly the information I needed in clear and very understandable steps. Thank you. This saved my evening.
Thanks Brink. A wonderful tut that worked great and made the family happy with a lot of recovered music and photos. Thanks again.
Flysjet
You're most welcome Flysjet. I'm happy to hear that you were able to recover your music and photos. :)
This is a very good tutorial. I just saw it for the first time. Thanks Brink. But it is really unfortunate that MS makes us jump thru all those hoops to look at our data. I now know why I will stick with Macrium.
Saved, thank you!
