Event Viewer One Click Clear
Page 1 of 11 123 ... LastLast
    How to Clear Event Viewer with One Click in Windows
    This will show you how to create a command line shortcut that will clear all of the Event Viewer logs in one click.
    Here is a batch file that can help you clear the event viewer in one click.
    Download this file above..
    Unzip on your desktop.
    You can use the task scheduler to give it a high priority so you won't get a UAC prompt
    See Brink's Tip HERE
    Or, just copy this script and paste in notepad and save as Clean Viewer.BAT
    Right click, and click on Run as administrator to run the file
    @echo off
    FOR /F "tokens=1,2*" %%V IN ('bcdedit') DO SET adminTest=%%V
    IF (%adminTest%)==(Access) goto noAdmin
    for /F "tokens=*" %%G in ('wevtutil.exe el') DO (call :do_clear "%%G")
    echo.
    echo goto theEnd
    :do_clear
    echo clearing %1
    wevtutil.exe cl %1
    goto :eof
    :noAdmin
    exit
  1. Posts : 557
    Windows 7 x64 Ultimate SP1
    Added Virtual PC clean log.
  2. Posts : 524
    Windows 7 SP1 x64
    Very nice!
    I clean the Event log because it gets full of error/warning events...
    This will shorten the time needed to clean it out!
    Thanks!
  3. Posts : 557
    That's the main reason why I created this script. Microsoft is supposed to re examine the viewer to make it less scary with usless warnings.
    Happy to help.
  4. Posts : 28,845
    Win 8 Release candidate 8400
    Z
    Really nice thanks
  5. Posts : 8,476
    Windows® 8 Pro (64-bit)
    Very nice.:)
  6. Posts : 557
    Pleasure guys.
    There's some very good stuff in this section!!
  7. Posts : 1,065
    Very useful, thanks heaps Zardoc!!
  8. Posts : 557
    My pleasure.
  9. Posts : 36
    Windows 7 64-bit
    Even shorter event clear script...
    This is an even shorter script to clear the event logs and will cover new logs as well as the current ones (Don't remember who I got it from, but works fantastically):
    Clear_All_Logs.bat
    OR you could also paste the following into a new batch file:
    @echo off
    echo.
    echo Event Logs have been cleared! ^<press any key^>
    goto theEnd
    :do_clear
    echo clearing %1
    wevtutil.exe cl %1
    goto :eof
    :noAdmin
    echo You must run this script as an Administrator!
    echo ^<press any key^>
    :theEnd
    pause>NUL
