Event Viewer One Click Clear
Page 2 of 11 FirstFirst 1234 ... LastLast
  1. Posts : 557
    Windows 7 x64 Ultimate SP1
    Someone seems to know code better than I do.
    Seems to work (I say that because I don't understand the code)
    Let's say you don't want to have to press exit key every time. We can modify this way
    @echo off
    FOR /F "tokens=1,2*" %%V IN ('bcdedit') DO SET adminTest=%%V
    IF (%adminTest%)==(Access) goto noAdmin
    for /F "tokens=*" %%G in ('wevtutil.exe el') DO (call :do_clear "%%G")
    echo.
    echo goto theEnd
    :do_clear
    echo clearing %1
    wevtutil.exe cl %1
    goto :eof
    :noAdmin
    exit
    Download
    Nice. I'll try it a while and check. :)
    Event Viewer One Click Clear Attached Files
  2. Posts : 1
    I am logged in as administrator and I keep getting access is denied error when trying to clear out my event logs. Why?
    I have tried this script, the command prompt, the event viewer doesn't event have a clear function available. Can anyone help?
  3. Posts : 557
       #12
    Hi and welcome to the forums.
    Even if you are logged in as administrator you must right click the command and choose run as administrator for it to work.
  4. Posts : 9
    Windows 7 Ultimate
    Thanks..!
  5. Posts : 17,322
    Win 10 Pro x64
       #14
    Wow, Thank's Zardoc, That is a major timesaver!
  6. Posts : 557
       #15
    Pleasure dude.
    Give rep if you like.
  7. Posts : 17,322
    Win 10 Pro x64
       #16
    Zardoc said:
    Pleasure dude.
    I Like, and I did + rep.
  8. Posts : 557
       #17
    Thanks Derek.
    Happy you like it.
  9. Posts : 23
    Win7 x64
       #18
    lightningltd said:
    This is an even shorter script to clear the event logs and will cover new logs as well as the current ones (Don't remember who I got it from, but works fantastically):
    Attachment 33164
    OR you could also paste the following into a new batch file:
    @echo off
    echo.
    echo Event Logs have been cleared! ^<press any key^>
    goto theEnd
    :do_clear
    echo clearing %1
    wevtutil.exe cl %1
    goto :eof
    :noAdmin
    echo You must run this script as an Administrator!
    echo ^<press any key^>
    :theEnd
    pause>NUL
    This is way better than the first batch file that was posted!!!! Thanks lightningltd!!!
  10. Posts : 557
       #19
    Thanks Randy, but if you read the whole post, I have a modified one in shorter than that and it does the same job.
