Windows 7 - Tutorial Index
Page 3 of 7 FirstFirst 12345 ... LastLast
  1. Posts : 72,051
       #20
    Windows 7 Tutorial Index - H (2 of 2)
    A - B - C - D - E - F - G - H - I - J - K - L - M - N - O - P - Q - R - S - T - U - V - W - X - Y - Z
    H:
    Hide - Show Known File Extensions - Add to Context Menu
    How to Add "Show/Hide Known File Extensions" to Context Menu in Vista and Windows 7
    Hide or Unhide a File and Folder
    How to Hide or Unhide a File or Folder in Windows 7 and Vista
    Hide a Folder or Shortcut Icon
    How to Hide a Folder or Shortcut Icon in Vista and Windows 7
    Hide User Account
    How to Hide or Unhide a User Account in Vista and Windows 7
    High Contrast Keyboard Shortcut - Enable or Disable in Windows
    How to Enable or Disable High Contrast Keyboard Shortcut in Windows 7, Windows 8, and Windows 10
    HIPM and DIPM - Enable in AHCI Link Power Management
    How to Enable HIPM and DIPM for your SSD and HDD in Windows 7
    Homegroup - Add Android Phone or Tablet
    How to Add an Android Phone or Tablet to a Homegroup in Windows 7 and Windows 8
    Homegroup - Add Computer or Join
    How to Join or Add a Computer to a Windows 7 Homegroup
    Homegroup - Add or Remove from Navigation Pane
    How to Add or Remove Homegroup from the Windows 7 Navigation Pane
    Homegroup - Allow or Prevent Computer to Join in Windows
    How to Allow or Prevent your PC to Join a Homegroup in Windows 7 and Windows 8
    Homegroup - Change File and Folder Sharing Settings
    How to Change Windows 7 Homegroup File and Folder Sharing Settings
    Homegroup - Change Password
    How to Change the Windows 7 Homegroup Password
    Homegroup - Create
    How to Create a Homegroup in Windows 7
    HomeGroup Desktop Icon - Add or Remove
    How to Add or Remove the HomeGroup Desktop Icon in Windows 7
    Homegroup Folder Shortcut - Create
    How to Create a "Homegroup" Folder Shortcut in Windows 7
    HomeGroup Icon - Change Default Icon
    How to Change the Default HomeGroup Icon in Windows 7
    Homegroup - Leave
    How to Leave a Windows 7 Homegroup
    HomeGroup - Link your Online ID and Share Files
    How to Link your Live ID and Share Files in Windows 7 Homegroup
    Homegroup Password - View or Print
    How to View or Print Your Windows 7 Homegroup Password
    Homegroup - Remove PC from in Windows 7 and Windows 8
    How to Remove Currently Unavailable PC you no longer have from Homegroup in Windows 7 and Windows 8
    Homegroup - Rename in Navigation Pane
    How to Rename "Homegroup" in Navigation Pane in Windows 7 and Windows 8
    HomeGroup Settings Shortcut - Create
    How to Create a "HomeGroup Settings" Shortcut in Windows 7
    HomeGroup Troubleshoot Shortcut - Create
    How to Create a "HomeGroup Troubleshoot" Shortcut in Windows 7
    Host a Website - IIS7.5
    How to Host a website using IIS7.5
    HOSTS File - Add or Remove from Desktop Context Menu
    How to Add "Edit HOSTS file" to Desktop Context Menu in Vista, Windows 7, and Windows 8
    HOSTS File - Create a "Edit HOSTS file" Shortcut
    How to Create a "Edit HOSTS file" Shortcut in Windows 7 and Vista
    Hosts File : Use in Windows
    How to Access and Use the Hosts File in Vista, Windows 7, and Windows 8
    Hotkey Shortcuts for Windows 7
    A List of Shortcut Keys for Windows 7
    HungAppTimeout Threshold - Specify in Windows
    How to Specify HungAppTimeout Used to Determine a Hung Process in Windows
  2. Posts : 72,051
       #21
    Windows 7 Tutorial Index - I (1 of 4)
    I:
    Icon Cache - Rebuild
    How to Rebuild the Icon Cache in Vista, Windows 7, and Windows 8
    Icon Cache Size - Change in Windows
    How to Change the Icon Cache Size in Vista, Windows 7, and Windows 8
    Icon - Change Default Icon of a File Extension
    How to Change the Default Icon of a File Extension in Windows 7
    Icon - Make from Image
    How to Make a Icon with a Image
    Icon Size - Change in Windows Explorer
    How to Change the Icon Size in a Windows 7 Explorer Window
    Icons - Change Using Resource Hacker
    How to Change Windows 7 System Icons Using Resource Hacker
    Icons - Create DLL File with Customized Icons
    How to Make Your Own DLL File with Customized Icons
    Icons - Hide or Show on Desktop
    How to Hide or Show Desktop Icons in Windows 7
    IExpress Wizard Shortcut - Create
    How to Create "IExpress Wizard" Shortcut in Windows 7 and Windows 8
    Imaging strategies
    Imaging with free Macrium
    Incoming Connections Troubleshoot Shortcut - Create
    How to Create a "Incoming Connections Troubleshoot" Shortcut in Windows 7
    Include in library - Add or Remove from Context Menu
    How to Add or Remove "Include in library" in Context Menu in Windows 7 and Windows 8
    Index File Types - Add or Remove
    How to Add or Remove a File Type from Index in Windows 7 and Windows 8
    Index Location - Change
    How to Change Location Where the Index is Stored in Windows 7 and Windows 8
    Index Locations - Add or Remove
    How to Add or Remove Index Locations in Windows 7 and Windows 8
    Index - Rebuild
    How to Rebuild the Index in Windows 7 and Windows 8
    Indexed Locations - Enable or Disable Modifying in Windows
    How to Enable or Disable Modifying Indexed Locations in Windows 7, Windows 8, and Windows 10
    Indexer Backoff - Enable or Disable in Windows 7
    How to Enable or Disable Search "Indexer Backoff" in Windows 7
    Indexing - Enable or Disable in Windows
    How to Enable or Disable Search Indexing in Windows 7, Windows 8, and Windows 10
    Indexing Options Shortcut - Create
    How to Create a Indexing Options Shortcut in Windows 7
    Indexing - Pause
    How to Pause Indexing in Windows 7 and Windows 8
    Inherited Permissions Context Menu - Add in Windows
    How to Add Inherited Permissions Context Menu in Windows 7, Windows 8, and Windows 10
    Inherited Permissions for Objects - Enable or Disable in Windows
    Enable or Disable Inherited Permissions for Files and Folders in Windows 7, Windows 8, and Windows 10
    Input Language - Add or Remove
    How to Add or Remove a Keyboard Input Language in Windows 7
    Input Language - Change Default
    How to Change the Keyboard Layout in Windows 7
    Input Language for Keyboard - Add or Remove
    Install - Clean Install Windows 7
    How to Do a Clean Installation with Windows 7
    Install - Clean Install Windows 7 Ahead of Vista
    How to Install Windows 7 to a Partition Ahead of Installed Vista
    Install - Clean Install Windows 7 Ahead of XP
    How to Install Windows 7 to a Partition Ahead of Installed XP
    Install - Clean Install with a Upgrade Windows 7 Version
    How to Do a Clean Install with a Upgrade Windows 7 Version
    Install - Custom Install Windows 7
    How to Do a Custom Installation of Windows 7
    Install - Inplace Upgrade to Windows 7
    How to Do a Inplace Upgrade Installation from Vista to Windows 7
    Install or Uninstall Display Languages Shortcut - Create
    How to Create a "Install or Uninstall Display Languages" Shortcut in Windows 7
    Install Program from Network Shortcut - Create
    How to Create an "Install Program from Network" Shortcut in Vista, Windows 7, and Windows 8
    Install - Repair Install Windows 7
    How to Do a Repair Install to Fix Windows 7
    "Install Updates and Shut Down" - Change Default in "Shut Down Windows" Dialog
    How to Change "Install Updates and Shut Down" as Default Choice in Shut Down Windows Dialog
    "Install Updates and Shut Down" - Enable or Disable
    How to Enable or Disable "Install Updates and Shut Down" Option in Windows 7
    Install Windows 8 Developer Preview from within Windows to Upgrade
    How to Upgrade to "Windows 8 Developer Preview" from Windows 7, Vista, or XP
    Install Windows 7 FAST without a DVD or USB device
    How to Install Windows 7 FAST without a DVD or USB Device
    Install Windows 7 from the Windows 7 Desktop
    How to Do a Clean Install of Windows 7 from the Windows 7 Desktop
    Install Windows 7 from the Windows XP Desktop
    How to Do a Clean Install of Windows 7 from the Windows XP Desktop
    Install Windows 7 on Computer with Less than 512MB RAM
    How to Install Windows 7 on a Computer with Less than 512MB RAM
    Install Windows on MSATA (SSD) Drive
    How to Clean Install Windows on a MSATA (SSD) Drive
    Install Windows on System with MSATA and ISRT
    How to Clean Install Windows on System with MSATA and ISRT
    Install Windows 7 Without Using Any External Device
    Install - Upgrade XP to Windows 7
    How to Do an Upgrade Install from XP to Windows 7
    Installation Date and Time of Windows - Find
    See Original Installation Date and Time of Windows 7 and Windows 8
    Installation Failure of Windows 7 - Overcome
    How to Overcome most Windows 7 Installation Failures
    Installed Windows Updates Shortcut - Create
    How to Create a "Installed Windows Updates" Shortcut in Windows 7
    "Installing device driver software" Balloon - Enable or Disable
    How to Enable or Disable "Found New Hardware" Balloons During Device Installation
    Installation - Dual Boot Windows 7 and Vista
    How to Setup a Dual Boot Installation with Windows 7 and Vista
    Installation - Dual Boot Windows 7 and XP
    How to Setup a Dual Boot Installation with Windows 7 and XP
    Installation - Dual Boot Windows 7 and Windows 8
    How to Do a Dual Boot Installation with Windows 7 and Windows 8
    Installation - Dual Boot Windows 7 and Ubuntu
    How to Dual Boot Windows 7 and Ubuntu
    Installation Errors for Windows 7 : Troubleshoot Step by Step
    How to Troubleshoot Windows 7 Installation Errors Step by Step
    Installations - Custom Windows 7 Installations with vLite
    How to Use vLite to Trim Down Windows 7 for a Custom Installation
    Intel CPU - Diagnose
    How to Diagnose Intel CPU with Intel Processor Diagnostic Tool
    IntelBurnTest - Stress Test CPU
    Test your CPU Stability with IntelBurnTest
    Intel HD Graphics desktop context menu - Add or Remove in Windows
    How to Add or Remove Intel HD Graphics desktop context menu in Windows
    Intel Rapid Storage Technology Notification Icon - Hide or Show
    How to Hide or Show Intel Rapid Storage Technology Notification Area Icon in Windows
    Internet Connection Sharing - Enable
    How to Enable Internet Connection Sharing in Windows 7
    Internet Connections Troubleshoot Shortcut - Create
    How to Create a "Internet Connections Troubleshoot" Shortcut in Windows 7
    Internet Explorer 10 - 32-bit or 64-bit IE10 in Windows 7
    How to Enable 32-bit or 64-bit Internet Explorer 10 (IE10) in Windows 7
    Internet Explorer "about:Tabs" - Show More Rows of Sites
    How to Show More Rows of Sites in "about:Tabs" in IE9 and IE10
    Internet Explorer - Accelerator Add-ons - Add or Remove
    How to Add or Remove an Internet Explorer Accelerator Add-on
    Internet Explorer - Accelerator Add-ons - Enable or Disable
    How to Enable or Disable an Internet Explorer Accelerator Add-on
    Internet Explorer - Accelerator Button - Turn On or Off
    Turn "Display Accelerator Button on Selection" On or Off in Internet Explorer
    Internet Explorer - Accelerator - Set Default
    How to Set a Default Accelerator in Internet Explorer
    Internet Explorer Accelerators - Enable or Disable Usage
    How to Enable or Disable the Use of Internet Explorer Accelerators
    Internet Explorer - "ActiveX Filtering" - Turn On or Off
    How to Turn "ActiveX Filtering" On or Off in IE9, IE10, and IE11
    Internet Explorer - Add-ons - Enable or Disable Add-On Manager
    How to Enable or Disable Managing Internet Explorer Add-ons
    Internet Explorer - Add-ons - Enable or Disable Toolbars and Extensions
    How to Enable or Disable Internet Explorer Toolbars and Extensions Add-ons
    Internet Explorer - Add or Remove from Power Options in Windows
    How to Add or Remove Internet Explorer in Power Options in Windows
    Internet Explorer - Address and Search Bar - Change Size
    How to Change the Size of the Windows 7 Explorer and IE8 Address and Search Bar
    Internet Explorer - "Always close all tabs" Warning - Turn On or Off
    How to Turn the "Always close all tabs" Warning Message On or Off in Internet Explorer
    Internet Explorer 9 and Firefox - Allow or Prevent Websites to Request Your Location
    How to Allow or Prevent Websites to Request Your Location in IE9 and Firefox
    Internet Explorer - AutoComplete - Turn On or Off
    How to Turn AutoComplete On or Off in Internet Explorer
    Internet Explorer - Auto Suggest Typed URLs - Delete
    How to Delete Typed URLs in Internet Explorer Auto Suggest Drop Down List
    Internet Explorer - Browsing History - Create Shortcuts to Delete
    How to Create "Delete Browsing History" in Internet Explorer Shortcuts
    Internet Explorer - Browsing History - Delete
    How to Delete Browsing History of IE7 and IE8
    Internet Explorer 9 - Browsing History - Delete
    How to Delete the Browsing History of Internet Explorer 9 (IE9)
    Internet Explorer - Browsing History - Delete on Exit
    How to Set IE8 and IE9 to "Delete browsing history on exit"
    Internet Explorer - Caret Browsing - Restore Confirmation Prompt
    How to Restore the Caret Browsing Confirmation Prompt
    Continued on next post......
  3. Posts : 72,051
       #22
    Windows 7 Tutorial Index - I (2 of 4)
    I:
    Internet Explorer - Caret Browsing - Turn On or Off
    How to Turn Caret Browsing On or Off within Webpages
    Internet Explorer - Clicking Sound while Browsing Internet - Turn On or Off
    How to Change or Turn On or Off the Clicking Sound while Browsing Internet and Windows Exlporer
    Internet Explorer Command Bar - Customize
    How to Customize the Command Bar in IE9 and IE10
    Internet Explorer Command Bar - Move to Left or Right
    How to Move the "Command Bar" to the Left or Right in IE9 and IE10
    Internet Explorer - Command Bar - Turn On or Off
    How to Turn the Command Bar On or Off in IE7 and IE8
    Internet Explorer Command Bar - Turn On or Off
    How to Turn the Command bar On or Off in IE9 and IE10
    Internet Explorer - Compatilbility View - All Websites
    How to Display All Websites in Compatibility View in Internet Explorer
    Internet Explorer - Compatibility View - Turn On or Off
    How to Turn Internet Explorer Compatibility View On or Off for a Website
    Internet Explorer - Compatibility View Websites - Import and Export
    How to Import and Export Compatibility View Websites in Internet Explorer
    Internet Explorer - Compatibility View Updates
    How to Receive Internet Explorer Compatibility View Updates
    Internet Explorer - Content Advisor - Enable or Disable
    How to Enable or Disable Internet Explorer Content Advisor
    Internet Explorer - Content Advisor - Hide or Show in Internet Options
    Hide or Show Content Advisor in Internet Options for IE10 and IE11
    Internet Explorer - Content Advisor Password - Reset or Change
    How to Reset or Change Password of Internet Explorer Content Advisor
    Internet Explorer - Content Advisor Rating Levels - Change
    How to Change Ratings Level in Internet Explorer Content Advisor
    Internet Explorer - Content Advisor - Reset
    How to Reset Internet Explorer Content Advisor
    Internet Explorer - Content Advisor Shortcut
    How to Create an Internet Explorer Content Advisor Shortcut
    Internet Explorer - Content Advisor Specific Websites - Allow or Block
    How to Allow or Block Specific Websites in Internet Explorer Content Advisor
    Internet Explorer - Content Advisor Unrated Websites - Allow or Block
    How to Allow or Block Unrated Websites with Internet Explorer Content Advisor
    Internet Explorer - Context Menu - Enable or Disable
    How to Enable or Disable Internet Explorer Web Page Context Menu
    Internet Explorer - Cookies - Allow or Block
    How to Allow or Block Cookies in Internet Explorer in Vista and Windows 7
    Internet Explorer - Cookies - Delete
    How to Delete Cookies in Windows 7 and Vista
    Internet Explorer - Cookies - Import and Export
    How to Import and Export Cookies in Internet Explorer
    Internet Explorer - Cookies Per Site Privacy Actions - Import and Export
    How to Import and Export Internet Explorer Cookies Per Site Privacy Actions
    Internet Explorer - Cross-site Scripting (XSS) Filter - Turn On or Off
    How to Turn the Cross-site Scripting (XSS) Filter On or Off in IE8 and IE9
    Internet Explorer - "Delete Browsing History" - Enable or Disable Access
    How to Enable or Disable "Delete Browsing History on Exit" of IE9
    Internet Explorer Desktop Icon - Create in Windows 7
    How to Create a "Internet Explorer" Desktop Icon in Windows 7
    Internet Explorer - DOM Storage Cookies - Enable or Disable
    How to Enable or Disable DOM Storage "Cookies" in Internet Explorer and Firefox
    Internet Explorer Download Connections per Server - Change
    How to Change Maximum Download Connections per Server Limit in Internet Explorer
    Internet Explorer - Download History - Delete
    How to Delete and Clear the Download History in IE9, IE10, and IE11
    Internet Explorer - Download Location - Change Default Location
    How to Change the Default Download Location in IE9, IE10, and IE11
    Internet Explorer - Download Speed and Time
    How to See Download Speed and Time in Download Manager of IE9 and IE10
    Internet Explorer - Downloads - View and Track
    How to View and Track Downloads in in IE9, IE10, and IE11
    Internet Explorer - Empty Temporary Internet Files folder when closed
    How to Set Internet Explorer to "Empty Temporary Internet Files folder when browser is closed"
    Internet Explorer 10 - Enable 32-bit or 64-bit IE10 in Windows 7
    Internet Explorer Enhanced Protected Mode - Turn On or Off
    How to Turn On or Off Enhanced Protected Mode in IE10 and IE11
    IE11 Enterprise Mode - Enable or Disable for Users
    How to Enable or Disable Users to Turn On and Off Enterprise Mode in Internet Explorer 11
    IE11 Enterprise Mode - Turn On or Off for Sites
    How to Turn On or Off Enterprise Mode for Sites in Internet Explorer 11
    Internet Explorer - F12 Developer Tools - Enable or Disable
    How to Enable or Disable "F12 Developer Tools" in Internet Explorer
    Internet Explorer Favorites Bar - Customize Title Widths
    How to Customize Title Widths on Favorites Bar in Internet Explorer
    Internet Explorer Favorites Center - Pin and Unpin to Left Side
    How to Pin and Unpin "Favorites Center" to Left Side in IE9, IE10, and IE11
    Internet Explorer - Favorites - Import and Export
    How to Import and Export Favorites in Internet Explorer
    Internet Explorer Favorites - Import Firefox Bookmarks
    How to Import Firefox Bookmarks into Internet Explorer Favorites
    Internet Explorer Favorites - Import into Google Chrome Browser
    How to Import Internet Explorer Favorites into Google Chrome Browser
    Internet Explorer - Find on this Page
    How to Use "Find on this Page" in Internet Explorer
    Internet Explorer - First Run Set Up Pop-up - Enable or Disable First Run Set Up Pop-up
    How to Enable or Disable IE8 and IE9 First Run Set Up Welcome Screen
    Internet Explorer Full Screen F11 Mode - Enable or Disable Auto-Hide
    How to Enable or Disable "Auto-Hide" in Vista and Windows 7 Explorer Full Screen F11 Mode
    Internet Explorer - GPU Hardware Acceleration - Turn On or Off
    How to Turn GPU "Hardware Acceleration" On or Off in IE9 and IE10
    Internet Explorer History - View
    How to View Internet Explorer History of Visited Websites
    Internet Explorer - Home Page - Add or Change
    How to Add or Change the Home Page in Internet Explorer
    Internet Explorer - Home Page - Multiple for Pinned Sites
    How to Have Multiple Home Pages for Pinned Sites in IE9 and IE10
    Internet Explorer - Home Page - Open Only First or All
    How to Open Only the First or All Home Pages when Internet Explorer Starts
    Internet Explorer Home Page - Specify and Prevent Changing
    How to Prevent Changing and Specify a Default Home Page in Internet Explorer
    Internet Explorer - Individual Taskbar Previews - Enable or Disable
    How to Enable or Disable Internet Explorer Individual Tabbed Browsing Taskbar Preview Windows
    Internet Explorer - InPrivate Browsing Enable or Disable
    How to Enable or Disable Internet Explorer InPrivate Browsing
    Internet Explorer - InPrivate Browsing Shortcut
    How to Create a Internet Explorer InPrivate Browsing Shortcut
    Internet Explorer - InPrivate Browsing - Toolbars and Extensions
    How to Enable or Disable Toolbars and Extensions in Internet Explorer InPrivate Browsing
    Internet Explorer - InPrivate Browsing - Turn On
    How to Open a Internet Explorer InPrivate Browsing Window
    Internet Explorer 8 - InPrivate Filtering - Keep On
    How to Keep InPrivate Filtering On or Off in New Internet Explorer 8 Session
    Internet Explorer 8 - InPrivate Filtering - Turn On or Off
    How to Turn InPrivate Filtering On or Off in Internet Explorer 8
    Internet Explorer 10 - Install or Uninstall in Windows 7
    How to Install or Uninstall Internet Explorer 10 (IE10) in Windows 7
    Internet Explorer - JavaScript Timer Frequency Power Plan Settings
    How to Change "JavaScript Timer Frequency" Power Option Setting for IE9 and IE10
    Internet Explorer - Language Preference for Webpages
    How to Add, Remove, and Arrange Language Preference for Webpages in IE8 and IE9
    Internet Explorer - Location - Allow or Prevent Websites to Request
    How to Allow or Prevent Websites to Request Your Location in IE9, IE10, IE11, and Firefox
    Internet Explorer - Menu Bar - Always On or Off
    How to Force Internet Explorer to Always Have the Menu Bar Turned On or Off by Default
    Internet Explorer 8 - Menu Bar - Always on Top
    How to Put the Menu Bar Always on Top in Internet Explorer 8
    Internet Explorer - Menu Bar - Turn On or Off
    How to Turn the Menu Bar On or Off in Windows 7
    Internet Explorer - Move Stop and Refresh Buttons
    How to Move Stop and Refresh Buttons to Left or Right of Address Bar in IE9 and IE10
    Internet Explorer - New Tab - Change What Page it Opens To
    How to Change What Page a "New Tab" Opens to in IE9 and IE10
    Internet Explorer (No Add-Ons) - Open
    How to Open Internet Explorer in (No Add-Ons) Mode
    Internet Explorer (No Add-ons) Shortcut - Create
    How to Create an "Internet Explorer No Add-ons" Shortcut
    Internet Explorer (No Add-ons) - Change Start Page
    How to Change the Default Start Page for Internet Explorer No Add-ons
    Internet Explorer - not playing audio or video files
    How to Fix "Internet Explorer not playing audio or video files"
    Internet Explorer - Notify when Downloads Complete - Turn On or Off
    How to Turn On or Off Notify when Downloads Complete in Internet Explorer
  4. Posts : 72,051
       #23
    Windows 7 Tutorial Index - I (3 of 4)
    I:
    Internet Explorer Only Websites - Display in Firefox and Chrome
    How to Display IE-only Pages in Firefox and Chrome
    Internet Explorer - Open Recently Closed Tabs
    How to Open Recently Closed Tabs in IE9 and IE10
    Internet Explorer - "Organize Favorites" Shortcut - Create
    How to Create an "Organize Favorites" in Internet Explorer Shortcut
    Internet Explorer 11 Performance Dashboard - Open and Use
    How to Open and Use Performance Dashboard in Internet Explorer 11 (IE11)
    Internet Explorer 9 - Pin and Unpin Websites to Taskbar or Start Menu
    How to Pin and Unpin Websites from IE9 to the Taskbar or Start Menu
    Internet Explorer 9 - Pinning Sites - Enable or Disable
    How to Enable or Disable Internet Explorer 9 Ability to Pin Sites
    Internet Explorer Play Sounds in Webpages - Turn On or Off
    How to Turn On or Off Play Sounds in Webpages in Internet Explorer
    Internet Explorer - Pop-up Blocker Exceptions - Add or Remove a Website
    How to Allow Pop-ups from a Website in Internet Explorer
    Internet Explorer - Pop-up Blocker - Import and Export Settings
    How to Import and Export Pop-up Blocker Settings in Internet Explorer
    Internet Explorer - Pop-up Blocker - Turn On or Off
    How to Turn Pop-up Blocker On or Off in Internet Explorer
    Internet Explorer - Protected Mode - Turn On or Off
    How to Turn Protected Mode On or Off in Internet Explorer
    Internet Explorer - Reopen Last Browsing Session
    How to Reopen the Last Browsing Session in Internet Explorer
    Internet Explorer - Reopen Last Browsing Session - Disable or Enable
    How to Enable or Disable "Reopen Last Browsing Session" in Internet Explorer
    Internet Explorer - Restore or Remove from Default Programs
    How to Restore or Remove Internet Explorer from Default Programs
    Internet Explorer - Reset
    Internet Explorer - RSS Feed - Subscribe or Unsubscribe
    How to Subscribe or Unsubscribe to a RSS Feed in Internet Explorer
    Internet Explorer - RSS Feeds - Import and Export
    How to Import and Export RSS Feeds in Internet Explorer
    Internet Explorer 9 - Search
    How to Search in Internet Explorer 9
    Internet Explorer - Search Box - Add or Remove
    How Add or Remove the IE7 and IE8 Search Box
    Internet Explorer 11 Search Box - Hide or Show
    How to Hide or Show Search Box in Internet Explorer 11
    Internet Explorer 8 - Search from Address Bar
    How to Enable or Disable Search from Internet Explorer 8 Address Bar
    Internet Explorer - Search Providers - Add and Remove
    How to Add or Remove Search Providers in Internet Explorer
    Internet Explorer - Search Suggestions - Enable or Disable
    How to Enable or Disable Search Suggestions in Internet Explorer
    Internet Explorer - Security Zones - Add or Remove Sites
    How to Add or Remove Sites in Internet Explorer Security Zones
    IE Security Zones - Enable or Disable Level Settings
    How to Enable or Disable Changing Security Zone Level Settings in Internet Explorer
    IE Security Zones - Enable or Disable to Add/Remove Sites
    How to Enable or Disable Ability to Add or Remove Sites from Internet Explorer Security Zones
    Internet Explorer - "Show tabs on a separate row" - Turn On or Off
    How to Turn "Show tabs on a separate row" On or Off in IE9 and IE10
    Internet Explorer - SmartScreen Filter - Manually Check a Website
    How to Manually Check a Website with SmartScreen Filter in Internet Explorer
    Internet Explorer - SmartScreen Filter - Prevent Bypassing Warnings
    How to Prevent Users from Bypassing SmartScreen Filter Warnings in Internet Explorer
    Internet Explorer - SmartScreen Filter - Report Unsafe Website
    How to Report a Unsafe Website with SmartScreen Filter in Internet Explorer
    Internet Explorer - SmartScreen Filter - Turn On or Off
    How to Turn SmartScreen Filter On or Off in Internet Explorer
    Internet Explorer - Specify Days to Keep Pages in History
    How to Specify Days to Keep Pages in History in Internet Explorer
    Internet Explorer 10 (IE10) Spelling Correction - Enable or Disable
    How to Enable or Disable Spelling Correction in Internet Explorer 10 (IE10)
    Internet Explorer Startup - Last Session or Home Page
    How to Set IE10 and IE11 to Start with Last Browsing Session or Home Page
    Internet Explorer 11 Store your Passwords - Turn On or Off
    How to Turn On or Off to Store your Passwords for Websites in Internet Explorer 11 (IE11)
    Internet Explorer 11 Stored Passwords - View and Remove
    How to View and Remove Stored Passwords for Websites by Internet Explorer 11 (IE11)
    Internet Explorer - Tabbed Browsing - Enable or Disable
    How to Enable or Disable Internet Explorer Tabbed Browsing
  5. Posts : 72,051
       #24
    Windows 7 Tutorial Index - I (4 of 4)
    I:
    Internet Explorer Tabs - Drag and Drop
    How to Drag and Drop the Tabs in IE9, IE10, and IE11
    Internet Explorer - Temporary Internet Files - Browse
    How to Browse the "Temporary Internet Files" of Internet Explorer
    Internet Explorer - Temporary Internet Files - Disk Space Usage
    How to Change Disk Space to be Used by Internet Explorer "Temporary Internet Files"
    Internet Explorer - Temporary Files - Create Shortcut to Delete
    How to Create a "Delete Internet Explorer Temporary Files" Shortcut
    Internet Explorer - Toolbars and Extensions Add-ons - Enable or Disable
    Internet Explorer - Troubleshooting Issues
    Internet Explorer 9 - Uninstall
    How to Uninstall Internet Explorer 9
    Internet Explorer 11 - Uninstall in Windows 7
    How to Uninstall IE11 in Windows 7 to Restore Previous Version of Internet Explorer
    Internet Explorer 10 - Uninstall or Install in Windows 7
    Internet Explorer - Use Small or Large Icons
    How to Use Small or Large Icons in IE9 and IE10
    Internet Explorer - Webpage Privacy Report
    How to View the Webpage Privacy Report in Internet Explorer
    Internet Explorer - Webpages - Change Colors
    How to Change Colors Used for Webpages in Internet Explorer
    Internet Explorer - Webpages - Change Fonts
    How to Change Font Styles Used for Webpages in Internet Explorer
    Internet Explorer - Webpages - Change Text Size
    How to Change Text Size Used for Webpages in Internet Explorer
    Internet Explorer - Zoom Level
    How to Change the Zoom Level in Internet Explorer
    Internet Explorer - Zoom - Enable or Disable
    How to Enable or Disable the Zoom Level Option in Internet Explorer
    Internet Options - "Advanced" Tab - Add or Remove
    How to Add or Remove the Advanced Tab in Internet Options
    Internet Options - "Connections" Tab - Add or Remove
    How to Add or Remove the "Connections" Tab in Internet Options
    Internet Options - "Content" Tab - Add or Remove
    How to Add or Remove the "Content" Tab in Internet Options
    Internet Options - Enable or Disable
    How to Enable or Disable "Internet Options" in Windows
    Internet Options - "General" Tab - Add or Remove
    How to Add or Remove the "General" Tab in Internet Options
    Internet Options - "Privacy" Tab - Add or Remove
    How to Add or Remove the "Privacy" Tab in Internet Options
    Internet Options - "Programs" Tab - Add or Remove
    How to Add or Remove the "Programs" Tab in Internet Options
    Internet Options - "Security" Tab - Add or Remove
    How to Add or Remove the "Security" Tab in Internet Options
    Internet Options Shortcut - Create
    How to Create "Internet Options" Shortcuts in Windows
    Internet Sharing using Cross-Over cable
    Networking betwen two PCs
    Internet Time Synchronization
    How to Use "Internet Time" Synchronization in Vista and Windows 7
    Internet Time Synchronization Update Interval
    How to Change the Internet Time Synchronization Update Interval in Vista and Windows 7
    Internet Troubleshooting Guide
    Dinesh's Complete Internet Troubleshooting Guide
    Internet Website Shortcut - Create
    How to Create an Internet Website Shortcut in Windows
    Internetwork Troubleshooting Guide
    How to troubleshoot computer internetworking, the right way
    IObit Products - Uninstall Completely
    How to Completely Uninstall IObit Products
    IP Address - Change Automatically
    How to Change Windows IP Address Automatically
    IP Address - Find for a Router to Log into with
    How to Find the IP Address to Log into a Router
    IP Address - Locate and Find for Your Computer
    How to Find the IP Address of Your Computer
    IPv6 - Enable or Disable in Windows
    How to Enable or Disable IPv6 in Windows 7, Windows 8, and Windows 10
    iPod Touch/iPhone - Use as a Mouse
    How to Use your iPod Touch/iPhone as a Mouse for the Computer
    IPv6 Temporary Address - Enable or Disable
    How to Enable or Disable Temporary IPv6 Address Feature in Windows 7 and 8
    ISO - Disk Image File : Extract to the Desktop
    How to Extract an ISO File to the Desktop
    ISO File - Boot from without Burning to Disk
    How to Make Windows Boot Manager Boot an ISO from your Hard Drive
    ISO File - Burn to USB to Create Bootable USB with
    How to Get and Use the Windows 7 USB/DVD Download Tool
    ISO File - Create Bootable ISO from Installation Files
    How to Create a Bootable ISO from Windows 7 Installation Files
    ISO File - Create Bootable ISO from an Older ISO
    How to Create a Bootable ISO from an Older ISO
    ISO File - Create Bootable ISO from Windows 7 Student Download
    ISO or IMG file - Burn to CD or DVD
    How to Burn a "ISO" or "IMF" Disc Image file to a CD/DVD in Windows 7 and Windows 8
    iTunes Library- Transfer
    How to transfer your iTunes library via external media
  6. Posts : 72,051
       #25
    Windows 7 Tutorial Index - J (1 of 1)
    J:
    Jump Lists
    How to Open and Use Windows 7 Start Menu and Taskbar Jump Lists
    Jump Lists - Backup and Restore in Windows 7
    How to Backup and Restore Jump Lists in Windows 7
    Jump Lists - Change Number of Recent Items to Display
    How to Change the Number of Recent Items to Display in Windows 7 Jump Lists
    Jump Lists - Enable or Disable Pinning and Unpinning of Items
    How to Enable or Disable Pinning and Unpinning of Items in Windows 7 Jump Lists
    Jump Lists - Pin or Unpin Items
    How to Pin or Unpin Items in Windows 7 Jump Lists
    Jump Lists - Reset and Clear All Items
    How to Reset and Clear All Items in Windows 7 Jump Lists
    Jumplist Launcher - Create Custom Jump Lists
    How to Create Custom Jump Lists in Windows 7
    Junction Points - Restore to Default in Windows
    How to Restore Default Junction Points in Windows
  7. Posts : 72,051
       #26
    Windows 7 Tutorial Index - K (1 of 1)
    K:
    Kaspersky TDSSKiller: Detect / Repair TDSS Rookits
    How to Use Kaspersky TDSSKiller to Detect / Repair TDSS Rookits
    Kernal Memory Dump Files - Configure Windows to Create on BSOD
    How to Configure Windows to Create a Dump File when you get a BSOD
    Keyboard Input Language - Add or Remove
    Keyboard Layout - Change
    How to Change the Keyboard Layout Language in Windows 7
    Keyboard Layout Preview
    How to See a Keyboard Layout Language Preview in Windows 7
    Keyboard - On-Screen Keyboard Shortcut - Create
    How to Create a "On-Screen Keyboard" Shortcut in Vista, Windows 7, and Windows 8
    Keyboard - On-Screen Keyboard - Turn On or Off
    How to Turn the On-Screen Keyboard On or Off in Vista, Windows 7, and Windows 8
    Keyboard Properties Shortcut - Create
    How to Create a "Keyboard" Properties Shortcut in Windows 7
    Keyboard - Right Click using in Windows
    How to Right Click using Keyboard in Windows 7, Windows 8, and Windows 10
    Keyboard Shortcut - Assign to Program Shortcut
    How to Assign a Keyboard Shortcut to Open a Program and Shortcuts in Vista and Windows 7
    Keyboard Shortcuts for Windows 7
    Keyboard Shortcuts and Access Keys - Underline
    How to Underline Keyboard Shortcuts and Access Keys in Windows 7
    Kill Not Responding Tasks - Add to Desktop Context Menu
    How to Add "Kill Not Responding Tasks" to Desktop Context Menu in Windows
  8. Posts : 72,051
       #27
    Windows 7 Tutorial Index - L (1 of 3)
    L:
    Language and Region Settings - Copy to New Users and Welcome Screen
    How to Copy Your Region and Language Settings to New Users and Welcome Screen
    Language Bar - Hide or Show
    How to Hide or Show the Language Bar in Windows 7
    Language Bar - Remove Extra Language
    How to Remove the Extra Language from your Language Bar
    Language - Change Display Language
    How to Change the Display Language in Windows 7 Ultimate and Enterprise
    Language - Change Regional Format Language
    How to Change the Windows 7 Regional Format Language
    Language for Non-Unicode Programs - Change in Windows
    How to Change the Language for Non-Unicode Programs in Windows
    Language - Force to Overwrite All Users Display Language
    How to Overwrite the Display Language of All Users with the System Display Language
    Language Packs - Create "Install and Uninstall Display Languages" Shortcut
    Language Packs - Install and Uninstall
    How to Install and Uninstall Display Languages in Windows 7 Ultimate and Enterprise
    Last Access Timestamp - Enable or Disable in Windows
    How to Enable or Disable File and Folder "Last Access Time" in Windows
    Lastwake Command
    How to See What Woke Up Your Computer Last
    Libraries - Arrange Included Folders in any Order
    How to Arrange Folders Included in a Library in Any Order in Windows 7 and Windows 8
    Libraries Desktop Icon - Add or Remove
    How to Add or Remove the Libraries Desktop Icon in Windows 7
    Libraries Folder - Add or Remove from Navigation Pane
    How to Add or Remove the Windows 7 Libraries Folder from the Navigation Pane
    Libraries - Hidden and Empty Fix
    How to Fix Libraries when Hidden and Empty in Windows 7 and Windows 8
    Libraries Icon - Change Default Icon
    How to Change the Default Libraries Icon in Windows 7
    Libraries Icons - Change
    How to Change a Library Icon in Windows 7
    Libraries - Include a Network Folder
    How to Include a Network Drive or Folder in a Library in Windows 7 and Windows 8
    Libraries - Personal and Public User Folders
    User Folders in Windows 7 Libraries
    Libraries - Pin to Search in Start Menu
    How to Pin Libraries to Search and See More Results in Start Menu
    Libraries - Rename in Navigation Pane
    How to Rename "Libraries" in Navigation Pane in Windows 7 and Windows 8
    Libraries - Restore Default
    How to Restore the Default Libraries in Windows 7 and Windows 8
    Library and Folder - Pin to Start Menu
    How to Enable or Disable Pin Folders and Libraries to Windows 7 Start Menu
    Library - Cannot Rename Fix
    How to Fix Cannot Rename Library in Windows 7 and Windows 8
    Library - Change Default "New Library" Icon
    How to Change the Default New Library Icon in Windows 7
    Library - Create New
    How to Create a New Library in Windows 7
    Library - Create "Documents Folder" Shortcut in Windows
    How to Create a "Documents Library" Shortcut in Windows 7 and Windows 8
    Library - Create a "Downloads" Library
    How to Create a "Downloads" Library with Correct Icon in Windows 7 and Windows 8
    Library - Create a "Favorites" Library
    How to Create a "Favorites" Library with Correct Icon in Windows 7 and Windows 8
    Library - Create a "Games" Library
    How to Create a "Games" Library with Correct Icon in Windows 7 and Windows 8
    Library - Create "Music Library" Shortcut in Windows
    How to Create a "Music Library" Shortcut in Windows 7 and Windows 8
    Library - Create "Pictures Library" Shortcut in Windows
    How to Create a "Pictures Library" Shortcut in Windows 7 and Windows 8
    Library - Create a "Searches" Library
    How to Create a "Searches" Library with Correct Icon in Windows 7 and Windows 8
    Library - Create "Videos Library" Shortcut in Windows
    How to Create a "Videos Library" Shortcut in Windows 7 and Windows 8
    Library, Drive, and Folder - Pin to Start Menu
    How to Pin a Folder, Drive, and Library to the Start Menu in Windows 7
    Library - Hide or Show in Navigation Pane
    Hide or Show a Library in Navigation Pane in Windows 7 and Windows 8
    Library - Include a Folder
    How to Include a Folder in a Library in Windows 7
    Library-ms is no longer working - Fix in Windows 7 and Windows 8
    How to Fix the "Library-ms is no longer working" Error in Windows 7 and Windows 8
    Library Pane - Turn On or Off
    How to Turn the Library Pane On or Off in Windows
    Library - Remove an Included Folder
    How to Remove an Included Folder from a Library in Windows 7
    Library - Set Save Folder
    How to Set the "Default Save Location" Folder for a Library in Windows 7
    Library - Setup "Movie" Library in Windows Media Center
    How to Setup Media Center Movie Library in Windows 7
    Library View - Clear Changes
    How to Clear Changes made to Library View in Windows 7 and Windows 8
    License Information for Windows 7
    How to See Windows 7 License Information
    License Type of Windows - Determine if OEM, Retail, or Volume
    How to Determine if Windows License Type is OEM, Retail, or Volume
    Link Online IDs - Link in Windows 7
    Links Library - Create
    How to Create a Windows 7 "Links" Library with the Correct Icon
    Linux - Install on Windows 7 Virtual Machine using VirtualBox
    How to Install Linux on a Windows 7 Virtual Machine using VirtualBox
    "List Hidden Files" - Add to Context Menu in Windows
    How to Add "List Hidden Files" to Context Menu in Vista, Windows 7, and Windows 8
    "List Read-only Files" - Add to Context Menu in Windows
    How to Add "List Read-only Files" to Context Menu in Vista, Windows 7, and Windows 8
    Local Access Only Network Icon - Enable or Disable
    How to Enable or Disable "local access only" Network Icon in Windows 7 and Windows 8
    Local Area Connection Status - Create Shortcut
    How to Create a "Local Area Network Connection Status" Shortcut in Windows 7 and Windows 8
    Local Group Policies - Apply to All Users Except Administrators
    How to Apply Local Group Policies to All Users Except Administrators in Windows
    Local Group Policy - Backup and Restore in Windows
    How to Back Up and Restore Local Group Policy in Windows
    Local Group Policy Editor - Apply to a Specific User or Group
    How to Apply Group Policies to a Specific User or Group in Vista, Windows 7, and Windows 8
  9. Posts : 72,051
       #28
    Windows 7 Tutorial Index - L (2 of 3)
    L:
    Local Group Policy Editor - Add to Control Panel
    How to Add Local Group Policy Editor to Windows 7 Control Panel
    Local Group Policy Editor - Open
    How to Open the Local Group Policy Editor in Windows 7 and Windows 8
    Local Group Policy Editor - Quickly View Enabled Policies in Windows
    How to Quickly View Enabled Group Policies in Windows
    Local Group Policy - Reset to Default
    How to Reset Local Group Policy to Default in Vista, Windows 7, and Windows 8
    Local Hard Disks - Enable or Disable Backing up to
    How to Enable or Disable Backing up to Local Hard Disks in Windows 7
    Local Security Policy Editor - Open
    How to Open the Local Security Policy Editor in Windows 7 and Windows 8
    Local Security Policy Settings - Reset to Default in Windows
    How to Reset All Local Security Policy Settings to Default in Windows
    Local Users and Groups Manager - Open
    How to Open Local Users and Groups in Windows 7 and Windows 8
    Local Users and Groups MMC Snap-in - Enable or Disable
    How to Enable or Disable the Local Users and Groups MMC Snap-in
    Location - Allow or Prevent Websites to Request Your Location
    How to Allow or Prevent Websites to Request Your Location in IE9, IE10, and Firefox
    Location Aware Printing - Automatically Switch Default Printers
    How to Automatically Switch Default Printers with Location Aware Printing in Vista, Windows 7, and Windows 8
    Location - Change Computer Default Location
    How to Change the Default Location of your Windows 7 Computer
    Location - Create "Default Location" Shortcut
    How to Create a "Default Location" Shortcut in Windows 7
    Location - Create "Modem and Phone Location Information" Shortcut
    How to Create a "Phone and Modem Location Information" Shortcut in Windows 7
    Location - Enable or Disable Changing in Windows
    How to Enable or Disable Changing GeoID Location in Windows
    "Location" Tab in Region and Language - Add or Remove
    How to Add or Remove the "Location" Tab in Region and Language
    Lock Computer - Add or Remove from CTRL+ALT+DEL Screen
    How to Add or Remove "Lock Computer" from the CTRL+ALT+DEL Screen
    Lock Computer - Add to Desktop Context Menu
    How to Add "Lock Computer" to the Desktop Context Menu in Windows 7
    Lock Computer and Turn Off Monitor - Add to Desktop Context Menu
    How to Add "Lock Computer and Turn Off Monitor" to the Context Menu in Windows
    Lock Computer - Create Shortcut
    How to Create a Lock Computer Shortcut in Windows 7 and Windows 8
    Lock Computer - Enable or Disable in Windows
    How to Enable or Disable Lock Computer in Windows
    Lock Computer Screen - Display User Information or Not
    How to Display User Information or Not when a Windows Session is Locked
    Lock Computer Sound - Play in Windows
    How to Play Sound when Lock Computer in Windows 7, Windows 8, and Windows 10
    "Lock Drive" - Add to Context Menu of BitLocker Drives
    Add "Lock Drive" to Unlocked BitLocker Drives Context Menu in Windows 7 and Windows 8
  10. Posts : 72,051
       #29
    Windows 7 Tutorial Index - L (3 of 3)
    L:
    Lock Icon on Files and Folders - Remove in Windows 7
    How to Remove the Lock Icon from Files and Folders in Windows 7
    Logging off... Text Message - Change
    How to Change the "Logging off..." Text Message at Shut Down in Windows 7 and Vista
    Log Off - Add or Remove from CTRL+ALT+DEL Screen
    How to Add or Remove "Log Off" from the CTRL+ALT+DEL Screen
    Log Off - Add to Desktop Context Menu
    How to Add "Log Off" Computer to the Desktop Context Menu in Windows 7
    Log Off - Enable or Disable in the Start Menu
    How to Enable or Disable "Log off" in the Start Menu of Windows 7
    Log Off Shortcut - Create
    How to Create a Log Off Shortcut in Windows
    Log Off User in Task Manager
    How to Log Off a Local User in Vista and Windows 7
    Log On Automatically at Startup
    How to Automatically Log On a User Account at Windows 7 Startup
    Log On Automatically at Startup - Bypass in Windows
    How to Temporarily Bypass Automatic Logon at Startup in Windows
    Logon - Change CachedLogonsCount Entries Saved
    How to Change the Number of Domain Logon Cache Entries Saved in Windows
    Log On - Enable or Disable "Secure Logon" CTRL + ALT + DELETE
    How to Enable or Disable Secure Logon CTRL+ALT+DELETE in Windows 7
    Logon Information
    How to Display Information About Previous Logons During User Logon in Vista and Windows 7
    Logon - Run Applications and Documents at User Logon
    How to Run Specific Programs and Documents at User Logon in Vista, Windows 7, and Windows 8
    Log On Screen - Add or Remove Ease of Access Center
    How to Add or Remove Ease of Access Center from Windows 7 Log On Screen
    Log On Screen - Enable or Disable Shut Down without Logging On
    How to Enable or Disable Shut Down without Having to Log On
    Log On Screen - Change
    How to Change the Windows 7 Log On Screen Background
    Log On Screen - Change Font
    How to Change the Font on the Log On Screen in Windows 7
    Log On Screen - Change or Remove Text Branding
    How To Change or Remove the Windows 7 Log On Screen Text Branding
    Logon Screen - Change Text Color in Windows
    How to Change the Logon Screen Text Color in Vista and Windows 7
    Logon Screen - Fix Showing Only "Other User" and Last Logged On User
    How to Fix Windows 7 Logon Screen Showing Only "Other User" and Last Logged On User Icon
    Log On Screen Saver - Enable or Disable
    How to Enable or Disable the Windows 7 Log On Screen Saver
    Log On Screen Text Shadow - Change
    How to Change the Windows 7 Log On Screen Text Shadow
    Log On Screen Title and Text Message - Add
    How to Display a Log on Screen Title and Text Message in Vista and Windows 7
    Log On Sound - Custom "Windows Logon" that Speaks What You Like
    How to Create a Custom Logon Sound that Speaks What You Like
    Log On "Welcome" Text Message - Change
    How to Change the "Welcome" Text Message at Log On in Windows 7 and Vista
    Log On with User Name and Password
    How to Make Windows 7 Require a User Name and Password in Log On Screen
