Convert GPT Disk to MBR Disk
Page 4 of 9 FirstFirst ... 23456 ... LastLast
  1. Posts : 72,051
       #30
    Hello Fanaudi,
    Please go ahead and post back with a screenshot showing the full layout of your Disk Management window. This will let us know what your options may be. :)
  2. Posts : 21
    Windows 7 Ultimate 64 bit
       #31
    Re: How to Convert a GPT Disk to a MBR Diske:
    Brink ,
    Thanks for the quick response .
    Meanwhile , I have solved my compatibility issue ( error code 10 with a PCIe device ) . Nevertheless , if , for any other raison , I would choose to downgrade to Windows 7 , I would post you a screenshot of my Disk Management window . Btw , just formatting a GPT disc would set things strait , would'nt it or am I missing something here ? If this works , would I then need to reinstall a fresh version of Windows 7 or could I immediately boot a system image with my system repair disc ?
    Thanks again for your attention .
    Best regards ,
    fanaudi .
  3. Posts : 72,051
       #32
    That's great news Fanaudi. :)
    To downgrade back to Windows 7 from a UEFI (GPT disk) Windows 8, the tutorial below can help show you how to.
    Downgrade Windows 8 to Windows 7
  4. Posts : 21
       #33
    Re : How to Convert a GPT Disk to a MBR Disk
    Thank You Shawn ,
    I have now learned a little more about degrading . Very useful !
    Have a nice day.
    Chris .
  5. Posts : 72,051
       #34
    You're welcome Chris. I hope you have a good one as well. :)
  6. Posts : 21
       #35
    Hello Brink ,
    Just this small message to tell you that , like several other fellow users , I had enough of Windows 8 after 2 weeks on my desktop and decided to revert back to Windows 7 . The good news is that this was done without a single problem . Guess I was very lucky because , earlier after a full opgrade to Windows 8 , I noticed in the Disk Management that my System disc had remained MRB ( this is maybe normal only after an upgrade ? ) . All I needed to do was to insert my Windows 7 System Repair Disc , collect an W7 image from my secundary and the job was done in less than half an hour .
    Best regards ,
    Chris .
  7. Posts : 72,051
       #36
    That's great news Chris. :)
    Hopefully Windows 8 may work out for you in the future.
  8. Posts : 1
    win8 64
       #37
    hi,
    thanks for the tutorial.
    I tried to install win7 on my laptop with pre-installed win8. as you can from my attachment, I failed to proceed through step "convert mbn".
    Unfortunately I have already deleted and formated the partition with win8 so I cannot follow the guide you provided in the link above.
    do you have any solution for me?
    thanks in advance
    Attached Thumbnails Attached Thumbnails Convert GPT Disk to MBR Disk-20130120_125021.jpg
  9. Posts : 72,051
       #38
    Hello guesswhoo, and welcome to Seven Forums.
    The tutorial below may be best for this instead since you are wanting to downgrade to Windows 7.
    Hope this helps, :)
  10. Posts : 7
    Windows 8 Pro, Windows 7 Home Premium
       #39
    I'm unable to boot up Windows 8 GPT disk. I made a bootable usb that allows me to open Mini Partition Wizard though. Can I convert a partition from GPT to MBR using this?
