Show Desktop Shortcut - Create
Page 6 of 8 FirstFirst ... 45678 LastLast
  1. Posts : 72,052
       #50
    Hipster Doofus said:
    Shouldn't the tutorial be updated to say that now the right side of the system tray has a working show desktop button? Maybe it wasn't in 2009.
    Reread the tutorial which says there was/is a show desktop button. I don't get it. Why would you want another one?
    Each to his own.
    Hello Ken,
    There's already a note box for that at the top of the tutorial. I suppose some folks just want one for whatever reason. We certainly had enough requests for a separate "Show Desktop" shortcut. :)
  2. Posts : 28
    Windows 7 Professional x64 SP1
       #51
    The show desktop that is over on the very right side is in a silly spot (and is too small), in my opinion. I use this feature a fair amount so the old fashion style suits me better, over by the Windows icon.
    As it turns out, I unpinned, repinned, and restarted the computer twice and for some reason on the second go around, it now works. I have been able to drag and drop it by the Windows icon. I have since restarted the computer again and it is still there and working correctly. Something glichy must have been going on. Thanks for your help. Cheers!
  3. Posts : 72,052
       #52
    That's great news Jeff. I'm happy to hear that it's working properly now for you. :)
  4. Posts : 960
    Windows 7 Ultimate SP1 - 64 Bit
       #53
    A little annoying. Takes like 8 seconds to appear as closed. Other than that.
  5. Posts : 1
    Win 7 64 bit Home Premium
       #54
    Manual Show desktop shortcut works like a charm
    Thanks!
  6. q21
    Win7 Prof 32bit
       #55
    hello, I have disabled the win-shortcuts in the registry because I wanted to use win-1,2,3,etc for volume presets instead of application switching (win 7 32 prof). I managed to get this working, but the win-d shortcut got lost on the way, as expected. (at least in copernic winkey, I can't even remap it - seems like it's lost as long as I keep things this way). so I figured I would use win-t to toggle the desktop. I used this tutorial (actually i tried both methods in the first post), and both worked. - however, my impression is they are much (!) slower than good old win-d, which worked like lightning. it seems like these two shortcuts use a different procedured than win-d - or probably also than the icon in the far right corner on the taskbar does. this effect may be all the more obvious on slower systems, e.g. netbooks.
    is there a way to get this going faster?
    thanks
  7. Posts : 72,052
       #56
    Hello q21,
    You could use the built-in "Show Desktop" button on the far right of the taskbar as in the tutorial below instead. :)
    Show Desktop
  8. q21
    Win7 Prof 32bit
       #57
    hi brink, yes, I could, but point is, I really would like to do this without a mouse. Besides, I have the icon hidden to save space (via 7taskbartweaker).
  9. Posts : 72,052
       #58
    Yeah, Windows+D keys would be the only other way without using a mouse.
  10. Posts : 30
    Nice one mate working very nice :) Awesome method :)
