Show Desktop Shortcut - Create
Page 1 of 8 123 ... LastLast
    How to Create a "Show Desktop" Shortcut in Windows 7 and Windows 8
    Show Desktop was a feature present in Windows XP and Windows Vista, but has been changed to the Aero Peek/Show Desktop button on the bottom right corner of the screen, near the Notification Area in Windows 7 and Windows 8.
    This tutorial will show you how to create or download a Show Desktop shortcut that you can use anywhere in Windows 7 and Windows 8.
    By default in Windows 7, the taskbar button on the far right side is for Show Desktop and Aero Peek.
    OPTION ONE
    To Download the "Show Desktop" Shortcut
    1. Click/tap on the Download button below to download the Show_Desktop.zip file.
    2. Save the .zip file to your desktop.
    3. Open the .zip file, and extract (drag and drop) the Show Desktop shortcut to your desktop.
    4. Unblock the Show Desktop shortcut.
    5. In Windows 7, you can now Pin to Taskbar or Pin to Start Menu, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
    6. In Windows 8 and 8.1, you can Pin to Taskbar on desktop, Pin to Start screen, add to Quick Launch,assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
    7. When finished, you can delete the downloaded .zip file if you like.
    OPTION TWO
    To Manually Create the "Show Desktop" Shortcut
    1. Right click or press and hold on an empty area on your desktop, and click/tap on New and Shortcut.
    2. Copy and paste the location below into the location area, and click/tap on Next. (see screenshot below)
    %windir%\explorer.exe shell:::{3080F90D-D7AD-11D9-BD98-0000947B0257}
    3. Type Show Desktop for the name, and click/tap on the Finish button. (see screenshot below)
    4. Right click or press and hold on the new Show Desktop shortcut, and click/tap on Properties.
    5. Click/tap on the Shortcut tab, then click/tap on the Change Icon button. (see screenshot below)
    6. In the line under "Look for icons in this file", copy and paste the location below, and press Enter. (see screenshot below)
    %SystemRoot%\system32\imageres.dll
    7. Select the icon highlighted in blue above, and click/tap on OK. (see screenshot above)
    NOTE: You can use any icon that you would like instead though.
    8. Click/tap on OK. (see screenshot below)
    9. In Windows 7, you can now Pin to Taskbar or Pin to Start Menu, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
    10. In Windows 8 and 8.1, you can Pin to Taskbar on desktop, Pin to Start screen, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
    Victor Ly
  1. Posts : 30
    Windows 7 64bit Home
    not working for me! everything is fine until i reboot and the show desktop icon is no longer there...
  2. Posts : 52
    Windows 7 Professional
    Sorry about that. I have since updated the tutorial to make sure that does not happen.
    Have a good day,
    Victor Ly
  3. Posts : 30
    Thanks! it's working now!
  4. Posts : 30
    Not working on final release?
    Hi Victor, sorry to bother you again but since installing the retail version of windows 7 home I'm unable to put show desktop on the taskbar.
    If I drag it to taskbar it gets pinned either to windows explorer or to my computer, it doesn't stay directly on the taskbar, I have to click on windows explore or my computer and then its there like a jumplist.
    any suggestions?
  5. Posts : 17,322
    Win 10 Pro x64
    This didn't work for me either, but I found the shortcut in the Quicklaunch folder in Brinks tutorial " Quicklaunch - Enable or Disable " ,Right clicked on it to send to desktop ( create shortcut ). Then followed Charbroil57's tutorial on how to pin the Recycle bin to the Taskbar and that worked for me, I don't know if there is an easier way to go about it ?
  6. Posts : 30
    Thanks Derekimo, I've tried that and it works but its not ideal as I have to keep the icon eiter down one side or the other.
    The way the icon behaved after Viktor's tutorial was what I needed, hope he'll be able to fix it.
  7. Posts : 21
    Win7 Pro
    Show Desktop works near start button, can I get rid of
    This procedure worked perfectly. Is there any way to get rid of the small icon to the right of the time?
  8. Posts : 1
    Wiindows 7
    Creating the desktop icon on the task bar
    This is totally minor, but I was wondering if you could tell me what I did wrong or what the fix might be: I was able to install the desktop button on my task bar, but it is not actually the desktop icon...can I get the icon image? Thanks!
  9. whs
    Unfortunately this did not work for me. When I wanted to save the Notepad file, I get this message. I am puzzled. I guess I will use Win+D.
