Internet Explorer 10 (IE10) Spelling Correction - Enable or Disable
Page 1 of 3 123 LastLast
    How to Enable or Disable Spelling Correction in Internet Explorer 10 (IE10)
    Internet Explorer 10 (IE10) includes a new spelling correction feature that autocorrects and highlights misspelled words.
    In Windows 8, spelling correction is included in both Internet Explorer 10 (IE10) desktop and Windows UI (Metro) versions.
    This tutorial will show you how to enable or disable spelling correction in Internet Explorer 10 (IE10) in Windows 7 and Windows 8.
    Autocorrect misspelled words - When turned on, will autocorrect the spelling of your typed words on the fly if it is matched with the correct spelling of the word in the dictionary. For example, type squigly and press the space bar after it, and it will be autocorrected to squiggly.
    Hightlight misspelled words - When turned on, will highlight the misspelled word by having a red squiggly line under it.
    This will not work in IE11. Use this below for IE11 instead.
    How to Turn Spelling "Autocorrect" and "Highlight" Misspelled Words On or Off in Windows 8 and 8.1
       Tip
    Windows 8 includes IE10 already.
    To download IE10 Release Preview for Windows 7 to install, see:
    Internet Explorer 10 Release Preview - Microsoft Windows
    or
    Download Internet Explorer 10 Release Preview
    EXAMPLE: "Highlight misspelled word" in IE10
    NOTE: This is an example when typing a misspelled word here at SevenForums in IE10.
    Internet Explorer 10 (IE10) Spelling Correction - Enable or Disable-highlight-sf.jpg
    OPTION ONE
    Enable or Disable IE10 Spelling Correction in Windows 7
    1. In IE10, click/tap on Tools (menu bar), and Manage add-ons. (see screenshot below)
    Internet Explorer 10 (IE10) Spelling Correction - Enable or Disable-w7_ie10-1.jpg
    2. In the top left pane, click/tap on Spelling Correction, and do step 3 or 4 below for what you would like to do. (see screenshot below)
    Internet Explorer 10 (IE10) Spelling Correction - Enable or Disable-w7_ie10-2.jpg
    3. To Enable Spelling Correction in IE10
    A) In the bottom pane, check the Enable spelling correction box, click/tap on Close, and go to step 5 below. (see screenshot below step 2)
    4. To Disable Spelling Correction in IE10
    A) In the bottom pane, uncheck the Enable spelling correction box, click/tap on Close, and go to step 5 below. (see screenshot below step 2)
    5. Either reload/refresh the page/tab in IE10, or close and reopen IE10 to apply.
    OPTION TWO
    Enable or Disable IE10 Spelling Correction in Windows 8
  1. Posts : 10,994
    Win 7 Pro 64-bit
    Another nice tutorial, Shawn. So just for confirmation, if IE10 is installed on a Windows 7 machine, the "autocorrect misspelled words" option is not available? Only the "highlight misspelled words" feature is available?
  2. Posts : 72,046
    Hello Lee,
    Both "autocorrect misspelled words" and "highlight misspelled words" are available in IE10 on Windows 7 and Windows 8. :)
    For example, type squigly and press the space bar after it, and it will be autocorrected (if enabled) to squiggly.
  3. Posts : 10,994
    Win 7 Pro 64-bit
    Thanks for the clarification, Shawn. If and when I decide to install IE10 I think I'll disable the autocorrect feature. Most spell check dictionaries I've seen (like speckie, iespell, etc) are overly aggressive with their "corrections". I've used autocorrect features that have changed wot (web of trust) to with or what. Or changed ie (internet explorer) to i.e. (the Latin abbreviation for id est.) You have to catch these autocorrect mistakes and enter your personally used words into the autocorrect dictionary.
  4. Posts : 72,046
    Unfortunately in Windows 7, this enables or disables both options in IE10. There's not an option for only one of them.
  5. Posts : 10,994
    Win 7 Pro 64-bit
    Ahh... bummer!
  6. Posts : 72,046
    Indeed. Maybe in the final release we will be able to.
  7. Posts : 14,606
    graet tutrial shawn , cant imagine why anyone neeeds it thuogh
  8. Posts : 72,046
    Thank you Julian.
    There could be instances where autocorrect may incorrectly autocorrect a word you are typing. For example, initials, local slang, or foreign letter marks.
  9. Posts : 19,383
    I think he was being sir-caustic Brink
