Start Menu - Customize
Page 4 of 5 FirstFirst ... 2345 LastLast
  1. Posts : 541
    Can i have "my computer" and Control Panel icons, on start menu ?
  2. Posts : 72,058
       #31
    Hello stereo,
    You could set both "Computer" and "Control Panel" to Display as menu to have it expand out to see the icons. :)
  3. Posts : 541
    I know that, Brink.
    But i thought it's possible to see the "my computer" icon, as well.
  4. Posts : 72,058
       #33
    Only when you select the Computer button is when you should see it's icon display at the top right.
  5. Posts : 4
    Windows 7 64bit
       #34
    Thank you for the tutorial. It was very helpful.
  6. Posts : 72,058
       #35
    You're welcome Phantom. I'm glad that it was able to help. :)
  7. Posts : 350
    Good tutorial, very helpful :)
  8. Posts : 52
    Windows 7 Home 64bit
       #37
    I want to create a .reg file to be able to easily hide links, instead of having to go through on each computer and setting them I could just merge and restart.
    I'm guessing I just cant put =0 at the end of each one.
    [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]
    "Start_ShowHelp"=0
    "Start_ShowMyGames"=0
    etc
  9. Posts : 72,058
       #38
    Hello Nums,
    Yes, that would work as well. :)
  10. Posts : 7
    Windows 7 Pro 32bit,
       #39
    Can this be done for "All Users"?
    I know you wrote this quite a while ago, but is there a way to do this in the registry and have it apply to all users? We try to configure our systems so that all our users have the same experience to begin with. If they change it to something else, so be it. But I really want to give them a default.
