Hi there
@Brink -- Seems to work now on W7 x-64 ultimate -- maybe I mis-typed something but still fails on W8 Enterprise (X-64) . Office version also x-64.
Cheers
jimbo
Hi there
Cheers
jimbo
Hello Jimbo,
Nar, my Office 2013 is installed and activated on 64-bit Windows 8 Enterprise.
You might try to phone activate Office 2013 using the information in the blue note box at the top of the tutorial.
I cannot access the activation screen on MS Office 2013. I get a screen saying we are having temporary server issues. try again later. Will it has been five days since I bought the program and the same error is there. I cannot activate the program and I began classes in two days. Please help
Hello Hound, and welcome to Seven Forums.
You might see if you may be able to activate Office 2013 by phone instead.
Activate Office 2013 programs - support - Office.com
How to activate a Microsoft product by using Microsoft Product Activation Center
Microsoft Office 2013
To start the Product Activation Wizard, follow these steps:
- Open any Office program. For example, open Microsoft Word 2013.
- Click the File tab.
- Click Account, then click Activate Product.
- In the Microsoft Office Activation Wizard, choose I want to activate the software by telephone, then click Next.
- Click the drop-down menu, and then select the country or region in which you're located.
- The Product Activation Center telephone number appears under Step 1.
Hope this helps, :)
Shawn,
Thanks for replying. I cannot get the activation screen to display. Still getting temporary server issues message. I tried to activate by phone but they don't say Office 2013 on it and I end up getting cut off. If I could just get to the activation screen I will be satisfied but I can't get to it.
