Partition or Volume - Delete
Page 13 of 17 FirstFirst ... 31112131415 ... LastLast
  1. Posts : 94
    Windows 7 Enterprise x64 SP1
       #120
    lizziequirke said:
    I today noticed that there is a partition on my hardrive, i have tried to remove the partition using both of the above methods with no luck. when i try through the command prompt it shows an error message.
    im stuck for ideas on what to try
    Do you want to delete your D: drive or the 400 Mb partition?
  2. Posts : 72,062
       #121
    Hello Lizzie, and welcome to Seven Forums.
    If you are trying to delete your D: partition, then it's not letting you since you have the page file located on it. With the page file on the D: partition, it considers the D: partition as a system partition now. Windows will not let you delete a system partition or drive for the same OS that you are currently started in to prevent you from hosing it.
    To be able to delete the D: partition, you will need to move the page file back to your C: partition first.
    Could you also provide a screenshot of your Disk Management window showing all of your HDD's layout to see if anything else may prevent you from deleting it as well?
  3. Posts : 5
    windows 7
       #122
    I will move the page file to see if that works. please see below screenshot of my disk management window.
    Attached Thumbnails Attached Thumbnails Partition or Volume - Delete-diskmanagement.png
  4. Posts : 72,062
       #123
    Yep, it looks like it's only the page file causing it.
  5. Posts : 5
    windows 7
       #124
    Err..something has now gone horribly wrong and I cannot turn my laptop on it comes up with an error message BOOTMGR is missing....oops
  6. Posts : 94
       #125
    The reason why I asked this "Do you want to delete your D: drive or the 400 Mb partition?" is because you said you want to delete the "new found partition" (Volume 2) but in your picture you're actually trying to delete the D: partition (Volume 1).
    What did you do EXACTLY? Tell us every step you did.
  7. Posts : 72,062
       #126
    Lizzie,
    Could you list exactly step by step on what you did and how you moved the page file to see if a mistake may have been made?
    Run a startup repair to see if it can fix this for you. You may need to let it run and restart more than once.
  8. Posts : 5
    windows 7
       #127
    Okay, i clicked on computer then properties then advanced system settings, i then clicked on the advanced tab. them clicked on change under virtual memory then i unchecked the Automatically manage paging file size for all drives box. i then put custom settings into my c drive initial size and max size boxes and on the d drive checked no paging file box, then restarted my laptop.
    i cannot do anything on my laptop now its just a black screen with the error message on.
  9. Posts : 72,062
       #128
    Lizzie,
    For now, see if running a startup repair may help. You may need to let it run and restart more than once.
  10. Posts : 5
    windows 7
       #129
    Shawn,
    i cant start a system repair as when i turn my computer on it loads the toshiba screen then the error message shows and i cannot do anything else.
