Partition or Volume - Extend
Page 10 of 23 FirstFirst ... 8910111220 ... LastLast
  1. Posts : 28
    Windows 7 Professional x64 SP1
       #90
    Is it the Move/Resize Partition feature that I use Shawn? (shown below) I thought it might be the Merge Partition but that gave me an error message that that feature wasn't available in this version. Thanks, Jeff
    Forum 2.docx
  2. Posts : 72,046
       #91
    Move/Resize may be able to do it since Merge is not available.
  3. mjf
    Windows 7x64 Home Premium SP1
       #92
    Yes merge is a feature in the paid version. You will need to drag the handle all the way to the the left and apply.
    Also I suggest you run check file system (over on the left).
  4. Posts : 28
       #93
    The Move/Resize seems to have done the trick. There is a good video tutorial on the Partition Wizzard webiste that I suggest everyone watch who is thinking of doing this. I found it very helpful as there is a right way and a wrong way to do it.
    As suggested, I also ran the check file system on both my drives. I have since restarted my computer and everything appears to be working as desired. Thank you both for your help and your quick replies.
    Jeff
  5. Posts : 72,046
       #94
    That's great news Jeff. I'm happy that we were able to help. :)
  6. Posts : 925
    Windows 10 Pro
       #95
    Hi, using this method can I extend two partitions outside of one partition. In other words
    Partition A
    Partition B
    Partition C
    I want to take space from Partition B which has the extra space and give some to Partition A & C is this possible without loosing any data using the method in this tutorial? Yes, it is literally in that order on my PC :)
  7. Posts : 72,046
       #96
    Hello Jerome,
    Yes, but you will need to use a free program like Partition Wizard Home Edition to be able to though. Disk Management is to basic for that, and will not be able to do it.
  8. Posts : 925
    Windows 10 Pro
       #97
    I see without having to reboot and loosing data ? :) Superb :)
    Brink what makes you suggest this program over others ?
  9. Posts : 72,046
       #98
    Yes, without having to reboot and loosing data.
    That free progam is just one that I liked. If you have another disk management type program that you prefer, then it'll probably work just as well. :)
  10. mjf
       #99
    Partition Wizard is popular with many forum members (inc. me).
    Like any program it may fail for a range of reasons. I suggest:
    1) Never use it unless you have a full backup or if you have nothing to lose if it fails.
    2) In the past the Bootable version of the same product has been more robust for major partition operations since the Windows OS is out of the way. Version 6 mini Tool may have improved here.
