Partition or Volume - Extend
Page 11 of 23 FirstFirst ... 91011121321 ... LastLast
  1. Posts : 1
    Ok, I'm kind of confused. I'm trying to extend a partition (which is C:. I want to make the partition C larger) From what i'm looking at here I would select the volume of C and extend it. But, will this erase and data?
    There is my hard draive stuff. I want to make the unallocated space part of C
    So then end result would be one partition on that one harddrive
    Will the diskpart do that? Will it erase any data?
  2. Posts : 72,051
       #101
    Hello Oreos, and welcome to Seven Forums.
    You could use Method One in the tutorial to extend the C: drive into the 27.83 GB of unallocated space to have it as part of the available space on the C: drive now. :)
  3. Posts : 1
    Windows 7 Ultimate x32
       #102
    When I shrink more than one drive....there is different free spaces.....and I cannot merge them.....and When I right click on a drive...the extend option is unavailable...plz help......
  4. Posts : 72,051
       #103
    Hello TShahrear, and welcome to Seven Forums.
    Please post a screenshot of your Disk Management window showing all of your drive's layout. This way we can make sure that we give the proper advice. :)
  5. Posts : 13
    Windows 7 Enterprise x64
       #104
    Hi, I want to extend my Z drive on disk 1:
    However, it is to the left, so I downloaded MiniTool Partition Wizard Professional Edition Demo as per suggested and got this:
    So then I thought I'll download EASEUS Partition Manager Professional Edition Demo as per suggested and got this:
    Any ideas fellas?
  6. mjf
    Windows 7x64 Home Premium SP1
       #105
    I think you want the "Resize" option. Select partition z: the resize to take in the unallocated to the left.
    Caution:
    1) This type of operation can go wrong so make sure your Z: data is backed up. I believe data will be physically so it may take a little while.
    2) I recommend using the Bootable version of the tool rather than the installed miniTool for this type of operation. The miniTool should work but with a bit more risk.
    Merge is used to combine 2 allocated partitions and certainly wasn't available in earlier free versions anyway.
  7. Posts : 12,177
       #106
    I agree with mjf, in Partition Wizard select Resize, then drag the left side of the Z partition to the unallocated space.
    Backup your Z partition before starting the resize procedure.
    Best to use the CD or USB bootable version.
  8. Posts : 72,051
       #107
    Hello MzTearyuz,
    If the above doesn't work, then your could also temporarily copy everything from Z: into a New Folder on your D: drive, delete Z: , create new one big partition on Disk 1, then copy everything back to it.
  9. Posts : 13
       #108
    Hi, resize doenst work in either program because its a demo only.
    And i cant use the other drive because it is full.
  10. Posts : 72,051
       #109
    MzTearyuz,
    In that case, this workaround should be able to work for you:
    • On Disk 1, create a new partition with the 1450.80 GB of unallocated space.
    • Copy the contents from Z: to the new partition just created.
    • Delete the Z: partition until it shows as unallocated space.
    • Extend the new partition into the now unallocated space to have it all in the new partition now.
