Partition or Volume - Shrink
Page 13 of 21 FirstFirst ... 31112131415 ... LastLast
  1. Posts : 24
    Windows 7 home premium x64
       #120
    A few days ago, I accidentally used the clean all command to my main hdd...
    Luckily, I have back up the data the days before.. I have followed shawn's tutorial, so I think I might as well give this a try since I already clean my hdd
    The problem is when I use the "list disk" command, my hdd is there, but when I type "list vol" command, my hard drive doesn't show up..
    I thought that there was sth wrong with my laptop, so I tried this guide with my USB flash drive. I tried clean my USB, shrink it, and create the partition the same way that this guide does, AND it works..
    I wonder why it doesn't work for my hdd?
  2. Posts : 11,408
    ME/XP/Vista/Win7
       #121
    As have used Clean All, you have no partitions or Volumes on the HD.
    You now need to use this tutorial:
    Partition or Volume - Create New
  3. Posts : 24
       #122
    Ah, so you mean that I dont have to do the shrink blablabla if I used clean all? Thx for the quick reply theog.. I will try it now...
  4. Posts : 24
       #123
    Thx theog, it works like a charm... Now I have another question.. How do you create another partition when installing the windows? For example I have 465 gb hdd and I want to use 100gb for my boot hdd, and the rest for data hdd?
  5. Posts : 11,408
    ME/XP/Vista/Win7
       #124
    Take a look this tutorial, will show you how to from Windows install & Command line.
    SSD / HDD : Optimize for Windows Reinstallation
  6. Posts : 11
    Windows 7 Ultimate 32bit
       #125
    Hi. I want to shrink my HDD so that i can backup some files before formatting my PC, will this work? and after i format my PC will i be able to extend the HDD that i shrinked again :) Thank You.
  7. Posts : 72,058
       #126
    Hello Didaboss,
    Could you post a screenshot of your Disk Management (diskmgmt.msc) window showing your HDD's layout first?
    This will help determine what your options will be. :)
  8. Posts : 11
       #127
    Here you go :)
    P.S that System (E) HDD got created while i was formatting (re installing Windows) :)
    Attached Thumbnails Attached Thumbnails Partition or Volume - Shrink-capture.png
  9. Posts : 72,058
       #128
    Didaboss,
    Yes, you will easily be able to shrink the C: partition to have unallocated space to create a new partition with for your backups. :)
    For the best reliability of your backups though, I would recommend to have them on a separate physical HDD instead. This way if something should happen to this drive, the other one would still be there with your data/backups on it.
  10. Posts : 11
       #129
    Brink,
    Ok, Thank You very much. You're Great! :)
