Hello Suranjit,
Could you post a screenshot of your Disk Management showing your drive layout?
Hello Suranjit,
Here is the Screen shot of my Disk Management. I still can not create New Volume from my Unallocated space...
Thanks,
Suranjit
Hey Brink,
Thanks for your suggestion. I will try to use GParted. But they mentioned that it's only for x86 machine (for Windows). I don't know whether it will work for my machine or not.
Are there any free 3rd party software available for partitioning? I tried to use some others but those did not help me.
Thanks,
Suranjit
I used Partition Magic Home Edition. It worked. But now there is a drive in my "Hard Disk Drives [Local Disk (Q)]" but Disk Management does not show anything. Is it a fake? Can I remove that from my Computer views?
And for Shrink related things, if anyone wants to create partitions but don't want the trouble related to Virtual HDs then they should do two things:
1. Shrink a partition (will create an unallocated space). Can not create volumes (more than 1/2) since it's limited in Windows 7.
2. Use a third party like Partition Wizard to create a partition from that shrink volume.
Thanks,
Suranjit
Strange, could you post a screenshot of it Computer and what is shows now in Disk Management?
Yeah, it's still there after restarting. I can not open that one. Says, Q:\ is not accessible. Can not open.
It's disturbing thing.
Plz let me know if there is any way to remove that.
Thanks,
Suranjit
