Partition or Volume - Shrink
Page 4 of 21 FirstFirst ... 2345614 ... LastLast
  1. Posts : 9
    Windows 7 Home Premium 64 bit
       #30
    Brink said:
    Yulistana,
    You're not going to be able to using Disk Management, but you might see if you can with Partition Wizard. Just do not convert the disk to a dynamic disk if that option should come up.
    I've downloaded and inform you later for the progress.
    Many thanks for your assist.
  2. Posts : 72,050
       #31
    You're most welcome. Ok. :)
  3. Posts : 9
       #32
    Dear Bring,
    I’ve installing the Partition wizard as your advice, it seems works theoretically but I need to register first.
    I want to know about some partition created (automatically maybe) when I change C: Drive to be 100gb as below, it spend about 7.84mb unallocated size and I can’t join these size in another drive. The warning said no MBR free of slot etc… Is it okay to let the size unallocated?
    Thanks,
  4. Posts : 72,050
       #33
    Hello Yullistana,
    The free free 7.84 MB of unallocated space is normal. I can't remember exactly what it is for, but it's used for system and HDD partition management purposes.
  5. Posts : 9
       #34
    Bring,
    One more time advice.
    Last night after I registering partition wizard, try to partition C Drive, but it doesn't successfully due to C Drive is being used by system. It should be restart the laptop and application will be continuing remaining partition task. But I still worry to partition C Drive with previous warning, please advice.
    Thanks,
  6. Posts : 72,050
       #35
    Yullistana,
    I thought that you have partitioned C: to be about 100 GB already from your previous post.
    If you want another partition, you may need to shrink a differen partition for it instead of C: .
  7. Posts : 9
       #36
    Dear Bring,
    Not yet, I didn't registered at that time so my task partition could't be run 'till last night.
    I still stuck in my spacious C Drive, but honestly I'm happy that I can build another partition which is Win 7 Disk management couldn't do it (more than 5 drive).
  8. Posts : 1
    "Shrink" Button will not activate
    I have a new issue, I think. I am in the disk management, but am unable to click the "shrink" button. I have plenty of free space, but it will not let me click!
    Please help!
    Attached Thumbnails Attached Thumbnails Partition or Volume - Shrink-cant-shrink.png   Partition or Volume - Shrink-cant-shrink-cmd.png
  9. Posts : 72,050
       #38
    Hello NostalgicStone, and welcome to Seven Forums.
    Could you post a screenshot of your Disk Management window to help see what your drive layout is? This will help us better determine what may be wrong. :)
  10. Posts : 1
    Mystery Q: Partition
    Have same issue as Suranjit. Did complete reinstall of Windows and Q: partition appeared again. Cannot access partition and cannot see partition in Partition Master or Computer Management. How can I delete this partition? Please help!
