Partition or Volume - Shrink
Page 11 of 21 FirstFirst ... 910111213 ... LastLast
  1. whs
       #100
    That was a virtual disk. Those are created e.g. when you mount a Macrium image (each time) or when you install Office 2010. But as you saw, they disappear after the first reboot.
  2. Posts : 2
    windows 7
       #101
    hi there,
    I also have problem in shrinking my partition. I went through all the pages in this topic but still not sure of what I can do.
    here is the image of my hard drive
    my laptop is TOSHIBA L630, 500GB hard drive, WINDOWS 7-64bit
    now I have some question to ask you guys about
    1. I have 500gb hard drive but why it only shows 465.75 GB, I just wonder where is the other?
    2. I want to shrink my C to around 80GB, but I don't know how to do it. as u can see in the picture, the unallocated there is the maximum GB that I can shrink
    3. about the 2 other partition: the 1.46GB and 10Gb both ard hidden partition, what can I do with them, can I format one of them? when I click on the 10Gb there is only one option that I can do is to delete it.
  3. Posts : 11,408
    ME/XP/Vista/Win7
       #102
    Hi balabala
    A1)Take a look here:
    Hard Drive Size Capacities Calculator
    500 = 465.66.
    A2) As you are at maximum leave alone.
    A3) The 1.46g & 10g partitions, are your Recovery partitions.
  4. whs
       #103
    A2) You can do that with Partition Wizard - not with Disk Management. Make sure you backup the partition to an external drive before you fumble with it, just in case.
    If you create new partitions, make an extended partition first - not another primary partition.
  5. Posts : 2
    windows 7
       #104
    thank you THEOG and WHS for ur help, I finally shrinked the C to 80gb and created 2 more partitions.
    thanks hipsssssssssss
  6. Posts : 3
    Error during partition
    my laptop is Dell Inspiron 15R, 500GB hard drive, 64bit
    1. I have 500gb hard drive with which I was able to create a new drive E: with 100 GB space
    2. I want to shrink my C to around 80GB, currently it is 350 GB and E drive is 100 GB.
    When I try to shrink the C drive, it allows me to create an unallocated space of only 129GB but still it does not allow me to create a new volume for this unallocated space,
    Also I see a virtual Drive Q : which I am unable to delete
    Please help me out on this
  7. whs
       #106
    1. The virtual drive may be from an installation of e.g. Office 2010 or when you mounted an image from Paragon or Macrium. This virtual volume should disappear when you reboot.
    2. For creating your new volume, try BEST FREE Partition Manager Software for Windows supports all 32-bit & 64 bit Windows No-server OS.
  8. Posts : 3
    Thanks,
    But can you please elaborate on reboot so that the Q drive disappear.I am new to all this and just want your guidance.
  9. whs
       #108
    maheshkumar said:
    Thanks,
    Just power-off (or shut-off) your PC and then power-on again. Or just "Restart". Let us know whether the virtual drive disappeared.
  10. Posts : 3
    No..The virtual Drive is still there after reboot.
    Also for the partition tool, Do we need to back up the data before using it?
    because I do not have my OS CD to install it again
