Partition or Volume - Create New
Page 29 of 48 FirstFirst ... 19272829303139 ... LastLast
  1. Posts : 72,050
       #280
    Hello Sknvitty, and welcome to Seven Forums.
    Yes, some of these OEMs have a bad habbit of using up all four primary partitions that you can have on a HDD, and not leaving you an option to create another one. Could you post a screenshot of your Disk Management showing all of your drive's layout?
    Unfortunately, usually the only way to do this would be to create a set of recovery repair disks from your Lenovo laptop, delete the recovery partition(s) on the HDD until they are unallocated space, then use a free program like Partition Wizard Home Edition to extend the Windows 7 partition into the unallocated space. This is not a recommended option to do though. One mistake, or if something happens to the recovery repair disks, you will have no easy way to reinstall your Windows 7 again.
    Let's see what your screenshot looks like first though. :)
  2. Posts : 10
    7
       #281
    hi,
    Thanks a lot for your reply.
    Here is the screen shot
    the process looks scary :)
    Attached Thumbnails Attached Thumbnails Partition or Volume - Create New-partition.png
  3. Posts : 72,050
       #282
    Yeah, that's what I was afraid of. You already have 4 primary partitions, so you will not be able to create a new partition without doing the unrecommended method above to create a set of recovery disk and delete the OEM (Lenovo) partitions.
    I'd recommend to extend C: back into the unallocated space. If your laptop is able, it would be better to add a 2nd 2.5" HDD if you needed more space or a separate HDD instead.
  4. Posts : 10
    7
       #283
    Hello Brink,
    Thanks a lot for your reply. I was able to extend the C drive back into the unallocated partition.
    No way out to partition this then?
    The thing i was not comfortable is to leave 500 GIG in C drive itself! can't maneuver the space while saving files!
    Is there a way to format everything and start with new partitions?
    But I dont have the windows CD with me. I guess 7 has recovery mechanism.
    Once again Thanks
    vitty.
  5. Posts : 16,160
    7 X64
       #284
    If you run off the Lenovo recovery discs - you could use those to put yor pc back to what they call "factory" condition.
    The options on the oem discs vary a bit - but I expect they will allow restoring just the windows partition - and not the oem partitions . Sony has that option, something like this:
      My Computers
  6. Posts : 10
    7
       #285
    Will the EASEUS FREE Partition Manager be of any help?
  7. Posts : 16,160
    7 X64
       #286
    There is a better, easier way.
    If you make any partition changes - you may lose Fkey access to recovery partition - depends how Lenovo set it up. Even if you do, we can probably get it back.
    In any event - you must run off Lenovo recovery discs now - that is the first thing that should be done when you get a pc.
    Let me know when you have done that and I will write a little app. which will do the job for you in one click.
      My Computers
  8. Posts : 10
    7
       #287
    Hi SIW2,
    Thanks for your reply.
    How do we do the lenovo recover discs?
    sorry i never used lenovo with win 7 before.
    need your help.
  9. Posts : 16,160
    7 X64
       #288
    Creating Lenovo Recovery Media in Windows 7
    It will probably take a bit of space - 3 dvd's perhaps.
      My Computers
  10. mjf
    Windows 7x64 Home Premium SP1
       #289
    Brink,
    I think C: should be at least 100GB but depending what is in the extended partition D:, couldn't it be moved to the left and a new drive/partition created within it? You still have the 4 primaries.
