Partition or Volume - Create New
Page 32 of 48 FirstFirst ... 22303132333442 ... LastLast
  1. Posts : 72,052
       #310
    That's great news Karthigeyanj. You'r welcome. :)
  2. SMA
    MS Windows 7 Ultimate 64-bit SP1
       #311
    I shrinked my disk, chose "new simple volume" and the steps normally appeared till 9!
    when I choose finish a window appears: the operation selected will convert the disk to dynamic so I'll not be able to start installed operating system.. are you sure you want to continue?
    when I choose Yes another window pops up: the pack name is invalid.
    so.. what's wrong?
  3. Posts : 72,052
       #312
    Hello SMA, and welcome to Seven Forums.
    You DO NOT want to convert the disk to dynamic. Doing so could render Windows 7 unbootable.
    Could you post a screenshot of your Disk Management showing all of the HDD layout?
  4. SMA
       #313
    this is my disk management.
    Attached Thumbnails Attached Thumbnails Partition or Volume - Create New-manage.png
  5. Posts : 72,052
       #314
    SMA,
    Unfortunately, you already have the maximum of 4 primary partitions allowed on a disk thanks to how your OEM (HP) setup the HDD disk at the factory for your Windows 7 recovery partitions (System, Recovery, and HP_Tools). This is why you are not being allowed to create a new partition. You could extend the C: drive back into the "unallocated space" to add it back to C: .
    If you are able to, I would recommend installing a 2nd HDD to breakup into separate partitions instead. They are cheap these days, and it would be a lot less trouble for you. You wouldn't have to worry about messing up your Windows 7 factory recovery partions on your current HDD and not being able restore Windows 7 with them if needed in the future.
  6. SMA
       #315
    thanks for helping Brink!
  7. Posts : 72,052
       #316
    You're welcome SMA. :)
  8. mjf
    Windows 7x64 Home Premium SP1
       #317
    Given the large number of HP PCs sold and the number of times this problem arises, I hope HP occasionally glance at this forum.
  9. SMA
       #318
    >>> LIKE
    the problem of heating as well!
  10. Posts : 2
    WIn7 64 bit
       #319
    How to creat another partition on SSD
    Dear Brink,
    Thank you for this valuable instruction. Is it possible to do SHRINK and CREAT NEW drive on SSD using the same method explained here?
    I got a new Sony Vaio, VPCZ1 with 256 GB SSD flash drive & Win7 as OS. The problem it has only one drive (C) and I want to creat another drive (100 GB) for data, and leave the rest for OS.
    Should I follow the same steps explained here? which is much simpler than what is explained in other forums !
    http://forum.notebookreview.com/sony/467519-how-configure-raid-jbod-new-vpcz1-series-ssd.html
    Thank you
