#330
R3QuI3M,
Your "Recovery" partition is a primary partition. It's your OEM factory recovery partition that is use to be able to reinstall Vista back to how it was when the computer first came out of the box.
A logical partition is a extended partition. The information and links below can give you more detailed information about them though. :)
I tried the the diskpart part of the information here, but had no luck in formatting an 80GB SATA HDD with FAT32.
Here is what I I got when I would do the
DISKPART> list volume
Volume ### Ltr Label Fs Type Size Status Info
Volume 0 E DVD-ROM 0 B No Media
Volume 1 C NTFS Partition 50 GB Healthy System
Volume 2 D D NTFS Partition 98 GB Healthy
* Volume 3 RAW Partition 74 GB Healthy
DISKPART> format fs=fat32 quick
0 percent completed
Virtual Disk Service error:
The volume size is too big.
Hello darkhorse,
Unfortunately, you will not be able to format a partition/volume with FAT32 if the partition/volume is over 32GB.
Comparing NTFS and FAT file systems
I had that somwhere in my backhead
Many thanks for the reply.
why i still can't see any partition in computer. i already follow all the steps. but, new partition that i created still remain unallocated. how to solve this problem? and my new memory size reduce to 245gb from 490gb before...i still cant see any new partition in computer~~please help me~
Hello Zacky, and welcome to Seven Forums.
Before I'm able to offer some advice, could you post a screenshot of your Disk Management window showing the complete layout of your drive just to make sure we know what's happening? :)
