Partition or Volume - Create New
Page 34 of 48 FirstFirst ... 24323334353644 ... LastLast
  1. Posts : 7
    Brink said:
    Hello R3QuI3M, and welcome to Seven Forums.
    Since you already have 3 primary partitions, the 4th and following ones will be logical partitions. You will be fine with it as a logical partition though. :)
    Thanks for the reply,
    So, is recovery partition considered as primary partition? Can u tell me what the differences between logical and primary, and also recovery? I'm new.
    Thanks,:)
  2. Posts : 72,063
       #331
    R3QuI3M,
    Your "Recovery" partition is a primary partition. It's your OEM factory recovery partition that is use to be able to reinstall Vista back to how it was when the computer first came out of the box.
    A logical partition is a extended partition. The information and links below can give you more detailed information about them though. :)
  3. Posts : 7
    Brink said:
    R3QuI3M,
    Wow, thank you for the information. Now I get it.
    By the way, my system is Windows 7 Home Premium, not Windows Vista :).
  4. Posts : 72,063
       #333
    You're welcome. It applies to both.
  5. Posts : 514
    Windows 7 Ultimate
       #334
    I tried the the diskpart part of the information here, but had no luck in formatting an 80GB SATA HDD with FAT32.
    Here is what I I got when I would do the
    DISKPART> list volume
    Volume ### Ltr Label Fs Type Size Status Info
    Volume 0 E DVD-ROM 0 B No Media
    Volume 1 C NTFS Partition 50 GB Healthy System
    Volume 2 D D NTFS Partition 98 GB Healthy
    * Volume 3 RAW Partition 74 GB Healthy
    DISKPART> format fs=fat32 quick
    0 percent completed
    Virtual Disk Service error:
    The volume size is too big.
  6. Posts : 72,063
       #335
    Hello darkhorse,
    Unfortunately, you will not be able to format a partition/volume with FAT32 if the partition/volume is over 32GB.
    Comparing NTFS and FAT file systems
  7. Posts : 514
    Windows 7 Ultimate
       #336
    I had that somwhere in my backhead
    Many thanks for the reply.
  8. Posts : 72,063
       #337
    You're welcome.
  9. Posts : 1
    Windows 7 Home Premium 32bit
       #338
    why i still can't see any partition in computer. i already follow all the steps. but, new partition that i created still remain unallocated. how to solve this problem? and my new memory size reduce to 245gb from 490gb before...i still cant see any new partition in computer~~please help me~
  10. Posts : 72,063
       #339
    Hello Zacky, and welcome to Seven Forums.
    Before I'm able to offer some advice, could you post a screenshot of your Disk Management window showing the complete layout of your drive just to make sure we know what's happening? :)
