Partition or Volume - Create New
Page 35 of 48 FirstFirst ... 25333435363745 ... LastLast
  1. Posts : 4
    Windows 7 unlimited 32 bit
       #340
    first i have 2 thank u about ur comments and reply .... i gain a HUGE info from it :) ... i red all the 34 pages
    i notice that my problem is common and not just me
    the Dynamic disc thing
    i have 4 partition already so i have to delete one of them
    first i have to say that i'm creating a new partition to copy my data ( music , movies ...etc ) from drive C to another 1 so i can install windows 7 unlimited as i have starter which i dont like it
    since i dont have any external HDD i have to do this .... the point is when i red athors comment ... many recommend to instal the backup recovery to DVD's and delet this drive ... the question is sinse i will install a new windowse do i need this drive any more ??
    also i don't have a CD.ROM ( it's a mini laptop )
    so i can't back it up to DVD's
    so what do u think ??? do i need that drive ??
    THANKS :):)
    Attached Thumbnails Attached Thumbnails Partition or Volume - Create New-9-1-2011-8-47-21-am.png
  2. Posts : 72,052
       #341
    Hello Ron, and welcome to Seven Forums.
    If by "new Windows", you mean that you have a new retail Windows 7 installation disc to use to install Windows 7 with instead of using the HP "Recovery" and "HP Tools" partitions to do so, then no you do not need it.
  3. Posts : 4
       #342
    thank u .. i really appreciate ur reply :)
  4. Posts : 72,052
       #343
    You're welcome Ron.
    Do you already have the new Windows 7 setup on a bootable USB flash key drive to use to be able to install it since you do not have a DVD drive?
  5. Posts : 4
       #344
    i used to install new windows from the same link by the way u have a great forum :)
    but since awhile i found another way ... i used a tool called (( Windows 7 USB DVD Download Tool ))
    it's quit easy and simple all u need is a .ISO version and 3 steps to do it
  6. Posts : 72,052
       #345
    Yep, Option One at the link. It's a great program. :)
  7. Posts : 4
       #346
    ooops it's there !!
    that's mean it's not the link i used to open ..... it wasn't there
    but this forum still my NO.1 :)
  8. Posts : 72,052
       #347
    LOL
  9. Posts : 6
    Windows 7 Ultimate 32bit
       #348
    Dear ADMIN, thanks for such a nice tutorial, As per your Tutorial I succesfully shrinked 35GB from my C:/ drive then I wanted to create a new drive with that 35GB Space, According to your tutorial I did the same but in the end I got the Warning-
    "The operation selected will convert the disk to dynamic... are you sure you want to continue?"
    I clicked on NO as suggested by you in the end of tutorial, But the New drive with that 35GB space was not created, now what to do, plz help me......
    Either help me to create New Drive with that 35GB Unallocated space or Help me to combine that 35Gb Space to any of my Exixsting drives....
    Thanks in Advance......
    Here is the new screenshot Sir, plz help me now to use that unallocated space of 35GB.....
  10. Posts : 72,052
       #349
    Hello RK,
    Could you post a screenshot of your Disk Management window showing all of your drive's layout?
    This will better help to determine what your options may be. :)
