Partition or Volume - Create New
Page 41 of 48 FirstFirst ... 313940414243 ... LastLast
  1. Posts : 40
    window 7 64 bit
       #400
    gregrocker said:
    Please post back a screenshot of your maximized Disk management drive map and listings, using the Snipping Tool in Start Menu: Screen Shots
    Tell us exactly what it is you want to do and we will give you the steps.
    Hello, Greggrocker
    I would like to create a new partition so I can install Window 8 for dual boot, I have no problem to show you a screen shot but how I get to this step ( Disk management drive map and listings) . Thanks
    Sorry, I would be able to this step too.....
    This is my Disk management drive map and listings
    Attached Thumbnails Attached Thumbnails Partition or Volume - Create New-25-04-2012-8-03-29-pm.png
  2. Posts : 72,052
       #401
    Blueriver,
    Since you already have 4 primary partitions, you will not be able to do this in Disk Management. Instead, you could use the tutorial below to shrink your C: partition, then use that unallocated space between C: and D: to create a logical partition to install Windows 8 onto.
    Partition / Extended : Logical Drives
  3. Posts : 40
    window 7 64 bit
       #402
    Thank you, I got it....
  4. Posts : 72,052
       #403
    You're most welcome blueriver. I'm happy to hear you got it. :)
  5. Posts : 9
    windows ultimate 32 bit
       #404
    Hi
    I have one parimary partition (70 GB) and an unallocated space (396 GB) when I open disk management I want to create an extended partiton but your instraction is about primary partitions.
    Can you give us an instruction about create a new extended partition?
  6. Posts : 72,052
       #405
    Hello Payamazimi,
    Here you go. :)
  7. Posts : 9
       #406
    Hi Brink
    Thanks alot for your instruction.
    My problem was solved.
  8. Posts : 72,052
       #407
    You're most welcome. I'm glad that it was able to help. :)
  9. Posts : 2
    windows 7
       #408
    hello Brink,
    i have been trying to do this so i can install windows 8 on a seperate partition and dual boot with windows 7
    i have shrank my C: , and now have 100GB of unallocated space (as seen in screen shot)
    now in your tutorial you state to click no if you get a popup saying to change to dynamic ( in screen shot) so i do this but i am still left with my unallocated space, how do i make that to a logical or primary partition?
    thank you.
    Attached Thumbnails Attached Thumbnails Partition or Volume - Create New-computer-management.png   Partition or Volume - Create New-computer-management2.png
  10. Posts : 72,052
       #409
    Hello F4T3, and welcome to Seven Forums.
    Since you already have 4 primary partitions, you will not be able to create another primary partition with the unallocated space. Instead, you could use the tutorial below to create a logical partition with the unallocated space to then be able to install Windows 8 on. :)
