Partition or Volume - Create New
Page 20 of 48 FirstFirst ... 10181920212230 ... LastLast
  1. Posts : 72,167
       #190
    I agree Wolfgang. What has me stumped in that screenshot is how the first partition on that disk is a primary partition and the other 3 are dynamic on the same physical hard drive.
  2. Posts : 3
    windows 7
       #191
    partition
    Thanks It helped. Now i have 3 primary and 1 dynamic. But now when i try to install xp, there arent any partitions. there reads only "There is no disk." Is it something wrong with my xp-install disk or..?
    Attached Thumbnails Attached Thumbnails Partition or Volume - Create New-nimetoen01.jpg
  3. Posts : 8
    amazing tutorial thanks so much!
  4. whs
       #193
    I don't see a dynamic - where is it. A dynamic partition would show green, the light blue one is a simple partition.
    Your XP installation problem may be a missing Sata driver problem.
  5. Posts : 72,167
       #194
    Hello WHS,
    He had dynamic partitions in his previous screenshot before this change, but I think he had just gotten logical and dynamic mixed up in the one above. :)
  6. whs
       #195
    Brink said:
    Hello WHS,
    OK, I see. The previous screenshot was weird anyhow. He must have converted the 3 to dynamic himself.
  7. Posts : 72,167
       #196
    Yeah, I'm still not sure how he had one primary and 3 dynamic partitions/volumes on the same physical disk.
  8. Posts : 101
    w7
       #197
    Finally moved an unmovable file but new problem came up
    After several weeks of trying, following the instructions/advice found here, I had been unable to accomplish shrinking my C volume after several weeks of frustration with PerfectDisk.
    Following a suggestion in another forum I by used the freeware MyDefrag and it was able to move files that Perfect Disk couldn't and shrink C by 6 GB
    I hope that I will be able to shrink C more, but now I have encountered a new problem!
    When I shrunk my C volume using Windows 7 (after using MyDefrag) it created a 6GB unallocated “black” partition to the right of the C partition, and to the left of my logical “blue” D partition.
    When I tried to extend my logical blue D partition by right clicking the logical D partition the “extend volume” option is greyed out.
    Is there a way I could get around this to add the unallocated 6GB to the blue logical D partition??
    Thanks for your help!!
  9. whs
       #198
    Partition Wizard can do that. Windows cannot do it if the free space is to the left. But is D your factory recovery partition. If yes, I do not understand why you would want to increase the size.
  10. Posts : 101
    w7
       #199
    to clarify...
    "C" is the original drive from which I created the logical partition "F" after using your advice. Now I am trying to combine the Unallocated space with the F logical partition
    What would happen if I deleted the F partition (I have it backed up)??
    Would I then get a larger unallocated partition comprising of the space on F
    plus the 6gb "unallocated" space??
    If so could this new unallocated partition be made into a new "F" partition??
    Thank you guys you have been very helpful!
    Attached Thumbnails Attached Thumbnails Partition or Volume - Create New-screenshot.jpg
