Partition or Volume - Create New
Page 24 of 48 FirstFirst ... 14222324252634 ... LastLast
  1. Posts : 560
    WIN10
       #230
    Can you please post another screen of the disk management window?
  2. Posts : 5
    windows 7 home basic 64 bit
       #231
    in c drive ad the new volume h driv theexted driv opton is blanked out. onky the recovry drive has the option availble.
    Attached Thumbnails Attached Thumbnails Partition or Volume - Create New-screen-shot.png
  3. Posts : 560
    WIN10
       #232
    So you want to regain that (103MB) of unallocated space. The only partition from within windows that would be able to regain that space is the recovery partition.*
    Unless you use a 3rd program like Partition Wizard.
    Partition Wizard : Use the Bootable CD
  4. whs
       #233
    You also have to make sure that the space is unallocated - not only available.
  5. Posts : 41
    windows7
       #234
    thanx nice
  6. Posts : 5
    Windows 7 Home Premium 32bit
       #235
    hi all dear
    thanks alot for enlightening us!
    firs i apologize if my text have mistake(because my en. language is weak!)
    i have dell vostro 3500 laptop with win7 32 bit and 500 gb of hdd.
    from first i bought my laptop it has the only one drive named : c.
    i want another drive and partition to save my video and music and etc. how can i solve this problem and make at least 4 another drive to archive.
    i heard from some that they lose their hdd containers or win!
    id one want catch this.
    meanwhile i have recovery dvd.
    if i recover or change win. later dont lose my win. or other container?
    thanks alot again:)
  7. Posts : 72,052
       #236
    Hello Mjsalehi, and welcome to Seven Forums.
    Could you post a screenshot of your Disk Management (diskmgmt.msc) showing all drive layouts? This will give us a better idea of what you will be able to do with it. :)
  8. Posts : 5
       #237
    thanks alot brink!
  9. Posts : 72,052
       #238
    Mjsalehi,
    You will be able to use this tutorial to shrink your C: drive by how much you want to use for the other partitions as unallocated space. Afterwards, you can create a logical (light blue) partition from the unallocated space, then repeat the process on each logical partition to shrink and create a new one for how many logical partitions you want. If you get asked to convert the drive to a dynamic disk, then DO NOT DO SO. It will make your Windows 7 unbootable.
    However, considering that you only have 451GB on your C drive, you might consider getting a new hard drive and split that up into how many partitions you want on it instead. This way it can be a good backup drive as well.
  10. Posts : 5
       #239
    Thanks...
    But could you tell me the solutions step by step that how can i do that?
    How can i do everything that you told me to achieve my goal?
