#230
Can you please post another screen of the disk management window?
in c drive ad the new volume h driv theexted driv opton is blanked out. onky the recovry drive has the option availble.
So you want to regain that (103MB) of unallocated space. The only partition from within windows that would be able to regain that space is the recovery partition.*
Unless you use a 3rd program like Partition Wizard.
Partition Wizard : Use the Bootable CD
hi all dear
thanks alot for enlightening us!
firs i apologize if my text have mistake(because my en. language is weak!)
i have dell vostro 3500 laptop with win7 32 bit and 500 gb of hdd.
from first i bought my laptop it has the only one drive named : c.
i want another drive and partition to save my video and music and etc. how can i solve this problem and make at least 4 another drive to archive.
i heard from some that they lose their hdd containers or win!
id one want catch this.
meanwhile i have recovery dvd.
if i recover or change win. later dont lose my win. or other container?
thanks alot again:)
Hello Mjsalehi, and welcome to Seven Forums.
Could you post a screenshot of your Disk Management (diskmgmt.msc) showing all drive layouts? This will give us a better idea of what you will be able to do with it. :)
Mjsalehi,
You will be able to use this tutorial to shrink your C: drive by how much you want to use for the other partitions as unallocated space. Afterwards, you can create a logical (light blue) partition from the unallocated space, then repeat the process on each logical partition to shrink and create a new one for how many logical partitions you want. If you get asked to convert the drive to a dynamic disk, then DO NOT DO SO. It will make your Windows 7 unbootable.
However, considering that you only have 451GB on your C drive, you might consider getting a new hard drive and split that up into how many partitions you want on it instead. This way it can be a good backup drive as well.
Thanks...
But could you tell me the solutions step by step that how can i do that?
How can i do everything that you told me to achieve my goal?
