#240
What are you looking to do?
for example i want to have more than drive:c. means i want to have drive :d,e and f to divide my empty space on c drive.
Mjsalehi,
From your Disk Management screenshot, you should be able to shrink your C: dirve by how how much space you want to be used by the other partitons as unallocated space. From this unallocated space, you can create logical partitions like you wanted using this tutorial. :)
thanks alot,
i'll do this. might be helpfull.
thanks
Thanks a lot for another great tutorial.
Hi there, I recently just installed Win7 x64 and I want to create a partition from my main C:/ drive. It's a RAID 0 configuration with 2x 320gb hard drives. When I open up disk management to shrink the volume it only allows me to shrink up about 49% of it. I want to partition my Windows into a 60 or 80gb partition and organize my drives the way I had them in XP. I was able to do that and split the remainder into 2 partitions with XP. I have 2 other slower drives as well that I use for storage and other stuff that I don't want to install Win7 on.
Thanks for the help!
update: since i was fresh install after fresh install... I formatted and used the cmd during install to format my OS drive and just make partitions with diskpart
all set! thanks for the nice guide!
Hi All, I'm redoing a desktop and wish to create an even 800 gigabyte partition, however it seems when you try to make these larger partitions the 1000x24 rule doesn't work for them, ...they're always smaller by few 100 megs.
Is there a different multiple value (x24) that can be used or is a guessing game with the larger partitions?
Thnx,
-OEM
