BCDEDIT - How to Use
Page 4 of 16 FirstFirst ... 2345614 ... LastLast
  1. Posts : 16,161
    7 X64
       #30
    Did you run startup repair 3 times?
    If so, you may have the wrong partition marked Active.
    Boot PW cd and see what it tells you - free from here - burn the .iso to cd as an image - don't format the cd:
    http://www.partitionwizard.com/download.html
    You can get Easeus Pro instead / as well if you like - they are doing a Giveaway only for today
    http://www.giveawayoftheday.com/ease...+of+the+Day%29
      My Computers
  2. Posts : 8
    Yes i did run startup repair 3 times..
    I have Partition wizard open now..
    what is it exactly you want to know..?
    Chris
  3. Posts : 8
    The partition where Windows is located is active.. all other is inactive..
    Chris
  4. Posts : 16,161
    7 X64
       #33
    What does it say about each partition - the full details please.
      My Computers
  5. Posts : 16,161
    7 X64
       #34
    Curious, you have a Primary Active partition - Windows is installed on it - and several runs of startup repair gives bootmgr is missing?
    From 7 dvd cmd , type:
    bootsect /nt60 all /mbr
      My Computers
  6. Posts : 8
    Ok.. Not sure exactly sure what you mean by full details, but here goes : )
    Disk 1:
    File system: NTFS
    Capacity: 37.27GB
    Used: 86.96MB
    Unused: 37.16GB
    Status: none
    Type: Primary
    Disk 2:
    *:Windows 7
    File system: NTFS
    Capacity: 131.83GB
    Used: 114.69GB
    Unused: 17.14GB
    Status: Active
    Type: Primary
    *:Samsung
    File system: NTFS
    Capacity: 131.83GB
    Used: 101.05GB
    Unused: 82.40GB
    Status: none
    Type: Primary
    Disk 3
    *:Q
    File system: FAT32
    Capacity: 19.01GB
    Used: 13.42GB
    Unused: 5.59GB
    Status: Active
    Type: Primary
    Disk 4
    File system: Unallocated
    Capacity: 7.88MB
    Used: 0B
    Unused: 7.88MB
    Status: none
    Type: Logical
    *:Entertainment
    File system: NTFS
    Capacity: 97.66GB
    Used: 96.60GB
    Unused: 1.06GB
    Status: none
    Type: Logical
    *ownloads
    File system: NTFS
    Capacity: 97.66GB
    Used: 97.21GB
    Unused: 457.61MB
    Status: none
    Type: Logical
    *ownloads2
    File system: NTFS
    Capacity: 48.83GB
    Used: 48.43GB
    Unused: 417.11MB
    Status: none
    Type: Logical
    *:Pics and Progz
    File system: NTFS
    Capacity: 53.92GB
    Used: 53.07GB
    Unused: 867.88MB
    Status: none
    Type: Logical
    Chris
  7. Posts : 16,161
    7 X64
       #36
    Was RC on Disk 1?
    In Pw rt click Q select Modify>Set as Inactive.
    Then see what startup repair does.
      My Computers
  8. Posts : 8
    Yes RC was on Disk 1..
    I did as you said i both posts, But it still says BOOTMGR is missing..
    Chris
  9. Posts : 16,161
    7 X64
       #38
    Use the letter for 7 retail partition ( as seen by Diskpart in place of ?: It might be different from the letter you see in Windows and PW - press enter after each command)
    bcdboot ?:\windows /s ?:
    bootsect /nt60 ?:
      My Computers
  10. Posts : 8
    IT WORKED!
    Thank you so much SIW2..
    You're the man ! :)
    I owe you one :)
    Chris
