BCDEDIT - How to Use
Page 7 of 16 FirstFirst ... 56789 ... LastLast
  1. Posts : 16,161
    7 X64
       #60
    You're welcome, glad it worked for you.
      My Computers
  2. Posts : 3
    Windows 7 Ultimate 64-bit
       #61
    If only I could load BCDEdit....
    I've got a win7 ultimate 64-bit install. It resides on a 2-disk striped array and boots fine. I recently added Fedora 12 to a 3rd hard drive. The Fedora installer added grub to the system so I can dual boot with it and it works fine. I can get to either OS at boot time. Grub passes the boot to the regular windows 7 stuff via a "chainload" command when it is selected (this is what I understand anyway) so the standard Win7 boot stuff should be fully functional.
    Now, for the first time, I wanted to tweak some Win7 startup stuff and began the odyssey of getting acquainted with BCDEdit.exe.
    The problem I have is when I open an elevated command window and type bcdedit to examine the current setup I always get the message "The boot configuration data store could not be opened. The system cannot find the file specified." and am back at the command line.
    I also tried installing DualBootPro to see if an alternate method of boot editing would work and it fails too with its version of the same error. I suspect I am doing something really stupid here but just cannot figure it out. Does anyone have any pointers?
  3. Posts : 16,161
    7 X64
       #62
    I don't have grub straddling the disk code, but this should work:
    1. go to folder options and show hidden files and folders.
    2. Find the pale yellow Boot folder on the System partition.
    3. Open an elevated at the Boot folder. Type:
    bcdedit /store bcd /enum
    to see the boot menu entries.
    Then use the same /store bcd parameter in all the bcdedit commands.
    ( Or use bcdedit /store <the path to bcd> at an elevated cmd), e.g.
    bcdedit /store c:\boot\bcd [then whatever commands]
      My Computers
  4. Posts : 3
       #63
    SIW2, thanks a ton for giving this a try. Here's what happened.
    Switched the folder options as you indicated.
    Found \boot at the root level of my boot drive (C:)
    opened an elevated command window and did a cd to \boot
    typed the command you indicated
    got "There are no matching objects or the store is empty."
    when I do a DIR on \boot I see the BCD file and it even shows a modification date as of the moment I tried the command.
    Got anything else?
  5. Posts : 16,161
    7 X64
       #64
    The correct bcd store will be in the hidden Boot folder on the "system" partition - not necessarily the same as the "boot" partition.
    If you have one of those 100mb things - it should be in there.
    Rt click the 100mb in Disk Management and give it letter S.
    See if that helps. It's got to somewhere.
      My Computers
  6. Posts : 3
       #65
    You got it!
    You had the answer for me. I did have one of those "100 MG" things on my 3rd hard drive (not in the array). I assigned it a drive letter and switched display options to show hidden files, etc and sure enough, there it was.
    Thanks SIW2!
  7. Posts : 16,161
    7 X64
       #66
    You're welcome - glad you found it.
      My Computers
  8. Posts : 3
    windows 7
       #67
    from dual boot vs single boot
    hi,
    my problem is this: i installed w7 in f: from my drive with xp in c:. i would like to use only the drive with w7 without using c:, it makes a lot of noise. but it is not possible because the initial boot is on c:. i tried already the bcdboot f:\windows /s f: string but it didn't work. to work with bcdedit i do'nt feel to find out myself, so i'm asking you a hint what exactly i have to write. i hope i explained clearly , i want to boot only from my windows 7 drive without the use of the original xp drive with the boot file.
    thanks
    dj
  9. Posts : 16,161
    7 X64
       #68
    What do you mean bcdboot didn't work?
    Did it say it completed successfully?
    Did you mark the windows 7 partition Active, then set the Windows 7 HD first in the bios boot order?
      My Computers
  10. Posts : 3
    windows 7
       #69
    hi siw2,
    bcdboot gives me: error during the copy of the files. i translated it so i don't know what windows gives in english. w7 is the first in the boot order and is on an active partition. but xp onthe c: drive is the system partition.
