BCDEDIT - How to Use
Page 9 of 16 FirstFirst ... 7891011 ... LastLast
  1. Posts : 10,200
       #80
    Dwarf,
    My question is still why the author chose to use UUID instead of
    GUID. I feel like the author would be the only person qualified to answer why he made that choice.
    I am well aware of the definitions, per se.
  2. Posts : 9,582
    Windows 8.1 Pro RTM x64
       #81
    Lol, no problem. I guess that Limneos is the only person to answer that particular question. As far as I can make out, they are pretty much interchangeable, but as for why he chose one form over the other, only he can answer.
  3. Posts : 15
    Windows 7 x64
       #82
    Ok I think this is going to help me out later since I'm not by my computer at this time. I have a question though. I think Windows 7 is trying to boot from my E: drive but my "system" is setup on the C:. If I run through the BCDedit/ and I see that this is the case how would I go about getting the "boot" back onto the C: drive?
    Thanks!
  4. Posts : 10,200
       #83
    BuildnCastles,
    Shut off your computer.
    Turn on you computer.
    Immediately, and continuously, tap the F8 key until you get to the "Advanced Menu Options" screen.
    Choose the top choice, "Repair your computer"
    You will get a "System Recovery Options" window.
    Next you way along and sign in with your admin password if you would like.
    Finally, you get another menu.
    Choose the top choice again "Startup Repair"
    See if this doesn't solve your problem.
  5. Posts : 15
    Windows 7 x64
       #84
    Ok I ran "startup repair" and this didn't work. I'm noticing that it states that "Operating System: Windows 7 on E: Local Disk ". My windows 7 IS NOT installed on E: but it's installed on C: So to make myself clear C: was the main SATA drive used that I installed Windows 7 on originally.
    When I run /bcdedit the following pops up:
    Windows Boot Manager
    Identifier: {bootmgr}
    device: partition=C:
    description: Windows boot manager
    locale: en-US
    inherit: {global settings}
    default: {default}
    resumeobject: {c767c984-c249-11de-8b9d-c7ee4708438f}
    displayorder: {default}
    toolsdiplayer: {default}
    timeout: 30
    Windows Boot Loader
    Identifier: {default}
    device: partition=E:
    path: \Windows\system32\winload.exe
    description: Windows 7
    locale: en-US
    inherit: {bootloadersettings}
    recoveryseq: {c767c984-c249-11de-8b9d-c7ee4708438f}
    recoveryenab: Yes
    osdevice: partition=E:
    systemroot: \Windows
    nx: Optin
    Is this setup correctly? Please help.
    I ran Diskpart, lis vol and the following comes up as well:
    Volume#/Ltr/Label/Fs/Type/Size/Status
    Volume 0/F/DVD_ROM/UDF/DVD-ROM/3094MB/Healthy
    Volume 1/C/System Rese/NFTS/Partition/100MB/Healthy
    Volume 2/E/blank/NFTS/Partition/465GB/Healthy
    Volume 3/D/Tera/NFTS/Partition/931GB/Healthy
    I don't understand but my D: drive is my 1tb hard drive? When windows was working it was drive letter E:
    It still is looking at E: when trying to find system restore points; I know it used to pull the system restore points from the C: drive though. Shouldn't it be looking at C:? Is this the reason why it can't boot up? I can get to the login screen but it's completely black. Thanks for all the help!
  6. Posts : 1
    windows 7
       #85
    I need some Help
    i backed up an image of my windows 7 and i want to recover it in in several partitions
    the first recovery on partion c: works fine later i recover my windows 7 image into another partion and try to daul-boot them using you guide but it did not work i see
    Windows 7 Freezed
    Windows 7 Unfreezed <---won't load
    one partion will have windows 7 with deep freeze
    and the other with no deep freeze
    but i cant dual-boot them
    the pint is i want two Windows 7 in different partions recovered from and image and make them to daul-boot
    i hope you can help me
  7. Posts : 11,990
    Windows 7 Ultimate 32 bit
       #86
    This tutorial was referenced by Fred Langa in the the latest Windows Secrets edition. He posted the link to it in his article.
  8. Posts : 1
    Win7 64bits
       #87
    bcdedit /set {4c21825f-e04b-11dd-b760-00195b61617a} numpoc 2
    NOTE: This adds the 2 CPU Core support during boot, like you do in msconfig.
    numpoc 2 = numproc 2
  9. Posts : 13
    Windows 7 Pro 64-Bit
       #88
    Hi All,
    I have a weird entry in my current BCD file. Can someone help me to remove it? I get an error everytime I try to delete it with EasyBCD 2.0 Beta..
    My BCD looks like this:
    There are a total of 3 entries listed in the bootloader.
    Default: Windows 7 SLI
    Timeout: 2 seconds.
    EasyBCD Boot Device: D:\
    Entry #1
    Name: Windows 7 SLI
    BCD ID: {current}
    Drive: C:\
    Bootloader Path: \Windows\system32\osloadw7.exe
    Entry #2
    BCD ID: {57bc9ba3-7768-11de-8d7f-bc29a8a8e033}
    Drive: C:\
    Bootloader Path: \Windows\system32\winload.exe
    Entry #3
    BCD ID: {57bc9ba2-7768-11de-8d7f-bc29a8a8e033}
    Device: unknown
    Bootloader Path:
    Its entry #3 I'm trying to get rid of.
  10. Posts : 16,161
    7 X64
       #89
    bcdedit /delete {57bc9ba2-7768-11de-8d7f-bc29a8a8e033}
    What error message does Easy give you ?
      My Computers
