BCDEDIT - How to Use
Page 10 of 16 FirstFirst ... 89101112 ... LastLast
  1. Posts : 13
    Windows 7 Pro 64-Bit
       #90
    Won't that also delete Entry #2? They both seem to have the same BCD ID for some reason...
  2. Posts : 13
       #91
    I've just noticed my mistake. The BCD IDs are different by a single digit:
    Entry #2
     BCD ID: {57bc9ba3-7768-11de-8d7f-bc29a8a8e033}
     Drive: C:\
     Bootloader Path: \Windows\system32\winload.exe
     Entry #3
     BCD ID: {57bc9ba2-7768-11de-8d7f-bc29a8a8e033}
     Device: unknown
     Bootloader Path:
    I'll try deleting the erroneous entry tonight and let you know how I get on.
    I'll also post the error message from EasyBCD if I get a chance.
  3. Posts : 9,582
    Windows 8.1 Pro RTM x64
       #92
    This highlights a very important point. When using this tool (or an equivalent that does the same job), be extremely careful when typing in ID strings especially when deleting entries. A mistake here can cause problems necessitating in the reinstallation of your system.
  4. Posts : 13
       #93
    Agreed!
    I thought that EasyBCD was kicking out errors because the two BCD IDs were identical. Now that I've realised that they aren't identical, I don't know whether to be more or less concerned! :)
  5. Posts : 13
       #94
    OK, so the EasyBCD error message pops up when I go to Edit Boot Menu, and try to delete the third menu item.
    The message reads:
    Unhandled exception has occurred in your application. If you click Continue, the application will ingnore this error and attempt to continue. If you click Quit, the application will close immediately.
    Object reference not set to an instance of an object.
    And the contents of the Details tab:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.NullReferenceException: Object reference not set to an instance of an object.
       at (Object , String )
       at ..(String id)
       at ..ž(Object , EventArgs )
       at System.Windows.Forms.Control.OnClick(EventArgs e)
       at System.Windows.Forms.Button.OnClick(EventArgs e)
       at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
       at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
       at System.Windows.Forms.Control.WndProc(Message& m)
       at System.Windows.Forms.ButtonBase.WndProc(Message& m)
       at System.Windows.Forms.Button.WndProc(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
        Assembly Version: 2.0.0.0
        Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
        CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    EasyBCD
        Assembly Version: 2.0.0.90
        Win32 Version: 2.0.0.90
        CodeBase: file:///C:/Program%20Files%20(x86)/NeoSmart%20Technologies/EasyBCD/EasyBCD.exe
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Xml
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    {d5328ebc-2e72-444f-a14d-c560fac8e76b}
        Assembly Version: 0.0.0.0
    System.Configuration
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
        <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
  6. Posts : 13
       #95
    bcdedit /delete {57bc9ba2-7768-11de-8d7f-bc29a8a8e033} did the trick!
    Thanks all and apologies for my stupidity
  7. Posts : 9,582
       #96
    No problem. I'm glad that you have resolved your issue. :)
    It has highlighted the need to be careful when working with this tool.
  8. Posts : 5
    WINDOWS
       #97
    Hi Guys!!
    Sorry about my English
    I have a question!
    How can I use two Hard drives. The situation is: I have HP Dv7 and the owner of it wanna have it with Windows 7 and Windows XP. The laptop has two hard drives, and the bios doesnt suport to choose what drive to boot up. It only starts up on the First drive. Now I have the first drive with Windows 7 and the second with Windows XP. I did try to use easyBCD but didnt work. I tried to set it to boot Windows XP on Drive "D:" on easyBCD but didnt starts up. Only starts Windows 7.
    Is there any way to do That??
    Thanx in advance!
    EdioIlha
  9. Posts : 11,408
    ME/XP/Vista/Win7
       #98
    Have a read of those tutorials:
    Dual Boot Installation with Windows 7 and XP
    Use EasyBCD 2.0 in Win 7 & Win XP.
    http://neosmart.net/forums/showthread.php?t=642
  10. Posts : 5
    WINDOWS
       #99
    Thanx for your reply!!
    Is there any method to do that in diferent hard drives insted of diferent Partitions? without installing windows 7 after. I have Windows 7 installed in the first one Hard(500gb) drive and Windows xp in the second one Hard drive(160gb), not just partitions. I tried to setup with easyBCD but it shows me C:, D: and Boot options, not Disc0, Disc1 like when you go to Linux Tab options.
    Linux Tab
    Windows Tab
    EasyBCD View Settings Button
    Thx a lot
    EdioIlha
