#90
I tried doing this using the 4th option in the first post. I deleted the partition on the 2d dynamic disk successfully. Windows Disk Management shows the disk as unallocated. When I tried running the Wizard in the Partition Recovery Wizard in Partition Wizard Home Edition, the 2d drive shows up as Dynamic, not Unallocated. I am guessing that's why I cannot run the wizard on this disk. When I try, the option to click "next" is grayed out to initiate the wizard.
Am I right that the reason the Wizard won't run is because PW Home Edition doesn't think this 2d disk is unallocated? Anyway to force this through?
If not, how could it get this done manually. Thoughts?
