#160
Yeah, using any of the other methods would affect it since they would wipe the drive. You would indeed need to reinstall Windows afterwards if you went that route.
I am not able to convert drive dynamic to basic. My all drives have dynamic.
I have attached snapshot of problem.
Please give a solution.
Thanks.
Hello Keshavdsd, and welcome to Seven Forums.
You could use step 2 in OPTION ONE on the first page of this tutorial thread to convert Disk 0 from dynamic to basic. :)
Hello,
Iīve just tried option 2. Deleted the dynamic volume, and then created a new simple volume, but didnt format (i donīt want to loose my data). Now I cant see my files.
What goes wrong?
If I format, I will lose my data. Please help.
Hello Manimpz, and welcome to Seven Forums.
I guess, you didn't see this below OPTION TWO.
WARNING: Be sure to read the red WARNING box above. You will lose all data on the dynamic disk using this option.
When you created a new simple volume, it formatted the deleted volume, and now all the data is permanently gone.
Hello Friend,
I didnt formatted the Data. Just mess with the partition thing.
Ive just deleted de dynamic volume, and created a new partion, but didnt formatted it.
I think there is still hope.
A program wich can try to read the HD withou looking for the partition. Can you recommend me one?
Please go ahead and post a screenshot showing this in Disk Management to help see what options you may have. :)
Disk Management - Post a Screen Capture Image
Brink,
This can be usefull for someone else.
TestDisk - CGSecurity
Recover Lost or Deleted Partitions in Linux Using TestDisk | TechSource
Look at this:
https://www.youtube.com/watch?v=EncqYP1ijFg
Right now im scanning every cylinder in the harddisk. Itīs very slow.
Best regards.
