Convert a Dynamic Disk to a Basic Disk
Page 6 of 20 FirstFirst ... 4567816 ... LastLast
  1. Posts : 254
    Windows 8.1.1
       #50
    OK thanks for that.I see the distinction.
    Looking at the E_Tools partition, all I see is a Hewlett Packard folder with System Diags and a very small .dat file, the whole lot about 2.7MB. I ought to be able to copy that into somewhere safe and then copy them back after I've done the deed and then update the path to the new location? Like I said I would like to keep this.
  2. Posts : 13,354
    Windows 7 Professional x64
       #51
    I would leave the recovery and HP Tools partitions untouched. It may not be so easy to copy all the files, because many are hidden and cannot simply be copied back.
  3. Posts : 254
    Windows 8.1.1
       #52
    I'm sorry Jonathan, I'm lost now!
    You said "If you remove the 100MB partition, that will free up that slot. You can then create a Logical drive using Partition Wizard, which will allow you to create unlimited partitions within the 350GB space."
    But if I delete the 100MB partition I will lose what is on it, won't it? I must be missing something but I cannot see it!
    Unless the data remains and is 're-instated' later?
  4. Posts : 13,354
       #53
    Follow the tutorial completely: System Reserved Partition - Delete
    Basically, what you do is delete the 100MB partition, and then write new boot files onto the C partition.
    One addition to the Tutorial:
    Use Diskpart to also mark the WIn7 partition active from WIn7 DVD or Repair CD: Partition - Mark as Active
    Then click through to DVD/CD Recovery Tools list to run Startup REpair up to 3 separate times with reboots until WIn7 starts.
    Si: BFK wrote a tute for using Partition Wizard bootable CD, which also includes how to remove 100mb. It could also be used here. Partition Wizard : Use the Bootable CD
  6. Posts : 254
    Windows 8.1.1
       #55
    Well, that's me stymied!
    !. I used the repair disk I created when I got the system. It loaded files, got to a screen that wanted keyboard type. Not the same shown in the tut. Shift+F10 did nothing. Abort.
    2. Rebooted using disk 1 of recovery set created when I got the system. This time it loaded files and went into the recovery screen, asking me if I wanted to recover from hard disk (recovery partition) or recovery DVD. Shift+F10 did nothing. Abort.
    It looks like HP 'did it their way' which doesn't help me. I'm not sure what to do now. I did mail HP yesterday but have heard nothing yet. It looks like I'm stuck with this setup.
    Incidentally, I don't have a 100MB disk, I have a 199MB SYSTEM (F:) disk, I assume that is the one you mean, not that it matters now!
  7. Posts : 16,155
    7 X64
       #56
    I think the repair disc you run off from within windows doesn't have the install now screen - it goes straight to searching for installations.
    When it has finished that, click Next and select command prompt.
    Greg - thanks for finding the link.
    BTW - There is a giveaway today of EPMPRO 6. It has convert dynamic to basic capability.
    I haven't tested that particular function , the rest of it works very well.
    GOTD_EPMPRO6
      My Computers
  8. Posts : 254
    Windows 8.1.1
       #57
    Ah, Thanks for that SIW2, I had thought ah well, forget it, but I'm still in with a chance!
    I also got a notification about EMPro 6. I just bought Partition Wizard 2 days ago!
    I will have another go at deleting this partition when I get some more time. big backlog right now.
    Thanks.
  9. Posts : 254
    Windows 8.1.1
       #58
    Siw2
    Yes, you are right, I got to the command prompt like you said but its now getting a bit scary.
    This is what I've got so far:
    list disk = disk 0 online 465GB Free 0 B
    select disk = disk 0 is now the selected disk
    list partition = partition 1 primary 199MB offset 1024KB
    = partition 2 primary 451GB offset 200MB
    = partition 3 primary 13GB offset 452GB
    = partition 4 primary 103MB offset 465GB
    select partition 1 = partition 1 is now the selected partition
    delete partition override = The arguments specified for this command are not valid. For more information on the command type :Help delete partition
    command prompt>
    What next then? And would someone please confirm about my 199MB disk partition. Is that the one I need to delete? It is the active partition so I assume it must be. The 100MB is my HP_TOOLS partition. Have HP gone to 200MB or what?
    I can go no further at this point!
  10. Posts : 16,155
    7 X64
       #59
    If I were you, I would make your win7 partition "system" first.
    Boot back into 7 , and rt click and run as admin on sisparv6.cmd.
    Enter your win7 driveletter ( probably C ) as the new system partition.
    Enter N to adding existing boot menu entries.
    Enter N to marking a partition Inactive.
    It only takes about 3 secs to run.
    Then restart and you should see your win7 partition listed as "system, active, boot" in Disk Management.
    Then you can delete the 199mb partition.
      My Computers
