Switch Between Windows - Flip 3D Shortcut
Page 3 of 10 FirstFirst 12345 ... LastLast
  1. Posts : 72,051
       #20
    Hello Graham,
    Do you have Recent Programs and Recent Items turned on? You will need these on to pin it to the taskbar.
    https://www.sevenforums.com/tutorials....html#post1681
  2. Posts : 41
    Windows 7 (7000) public beta
       #21
    Yes Shawn, Recent items are turned on.
    On the 'right' click menu I have no usual - pin to taskbar -or- pin to start menu.
  3. Posts : 72,051
       #22
    You will need to have Recent Programs turned on as well.
  4. Posts : 41
       #23
    Yes, I have that on too.
    Proof of life
    Attached Thumbnails Attached Thumbnails Switch Between Windows - Flip 3D Shortcut-recent_programs.jpg
  5. Posts : 72,051
       #24
    Strange. I'm not certain why you cannot pin it then. Have you already tried the manual method to see if you can pin that one?
  6. Posts : 18,404
    Did you unblock the zip?
    I know it wouldn't let me pin the flip3d icon to the taskbar when I tried the one from the quick launch folder
    Appdata/roaming/microsoft/internet explorer/quicklaunch/switch between windows
    but the zip one always lets me.
  7. Posts : 41
       #26
    No, I still don't get it..
    Attached Thumbnails Attached Thumbnails Switch Between Windows - Flip 3D Shortcut-switcher1.jpg   Switch Between Windows - Flip 3D Shortcut-switcher2.jpg
  8. Posts : 72,051
       #27
    Graham,
    The shortcut located at the path in the right image above will not be allowed to be pinned. Have you tried to see if the shortcut, if created manually, may be allowed to be pinned for you?
  9. Posts : 41
       #28
    Brink said:
    Graham,
    SUCCESS!
    Thanks Brink.
    The zip apparently did not work for me, but creating manually did. Went back in the thread and followed the manual instructions. (Incl. change icon.)
    Attached Thumbnails Attached Thumbnails Switch Between Windows - Flip 3D Shortcut-pin3dflip.jpg   Switch Between Windows - Flip 3D Shortcut-pin3dflip2.jpg
  10. Posts : 72,051
       #29
    Graham, I'm happy to hear that you got it sorted. :)
