#50
Great tip and very handy - but I wonder if I could map this to my Razer mouse key?
Hello Chazcon,
You might look through it's options to see if it my already have one for something similar to Flip-3D that you can select to use for one of the mouse button (ex: middle click button or mouse wheel). If your mouse supports assigning to run a program when a button is clicked, then you could have it run this shortcut.
Awesome! Very few people know about the "3D-Flip" feature. Especially those who went from Windows XP to 7.
I used 3D-Flip all the time on VISTA, and was dissapointed, believing that it wasn't in Windows 7. I found a similar tutorial on another website.
I just use the "WinKey + TAB" and "Ctrl + WinKey + TAB" shortcuts, since it doesn't display in my recently used programs list.
wicked!!!
i never know this features exist..thanx brink
Ty very much for the info. I'm new to 7 and i was wondering if that function had a shortcut ( cause its cool anyway ), or if i could bind it on mouse wheel click. But the k/b shortcut its better cause i use wheel click for new tabs.
Peace.
i have a microsoft keyboard and try the flip key and it work but only one time, but flip works with all the other conbination keys, so you think my new board went bad all ready, this is my only problem with it so far
Hello G4b1t, and welcome to Seven Forums.
This can help show you how to assign your own keyboard shortcut to this shortcut. :)
Keyboard Shortcut - Vista Forums
Hello Jarp,
It may just be a setting in your Keyboard settings in the Control Panel that needs to be set properly. Did you install the latest version of your keyboard driver software? If you have done both of these, then restarting the computer may allow it to work properly again as well.
