Internet Explorer Cookies Per Site Privacy Actions - Import and Export
    How to Import and Export Internet Explorer Cookies Per Site Privacy Actions
    With Internet Explorer Per Site Privacy Actions, you can specify which websites are always or never allowed to use cookies, regardless of their privacy setting.
    This tutorial will show you how to import and export all of your personal Per Site Privacy Actions for cookies in Internet Explorer in Vista, Windows 7, and Windows 8.
    It can be handy to backup your Internet Explorer Per Site Privacy Actions by exporting them to a REG file so that you can use it to easily import your settings back, say after a clean install of Windows or after resetting Internet Explorer.
    EXAMPLE: Internet Explorer Per Site Privacy Actions
    Internet Explorer Cookies Per Site Privacy Actions - Import and Export-example2.jpg
    OPTION ONE
    To Export Internet Explorer Cookies Per Site Privacy Actions
    1. Press the Windows + R keys to open the Run dialog, type regedit, and press Enter.
    2. If prompted by UAC, then click on Yes (Windows 7/8) or Continue (Vista).
    3. In regedit, navigate to the location below. (see screenshot below)
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\P3P
    Internet Explorer Cookies Per Site Privacy Actions - Import and Export-stepa.jpg
    4. In the left pane, right click or press and hold on the P3P key,and click/tap on Export. (see screenshot above)
    5. Navigate to your Desktop, then type in a name (ex: IE_Per_Site_Privacy_Actions) you want for this REG file, and click/tap on Save.
    Internet Explorer Cookies Per Site Privacy Actions - Import and Export-save-2.jpg
    6. Now move this exported REG file to where you like to keep it at as a backup of all of your personal Internet Explorer cookies Per Site Privacy Actions.
    OPTION TWO
    To Import Internet Explorer Cookies Per Site Privacy Actions
    1. Double click/tap on the exported REG file (ex: IE_Per_Site_Privacy_Actions.reg) that was exported from OPTION ONE above to merge it.
    2. If prompted, click/tap on Run, Yes (UAC Windows 7/8) or Continue (UAC Vista), Yes, and OK to approve the merge.
    3. Close and reopen Internet Explorer (if open) to apply.
  1. Posts : 1,158
    Win7 HP (x64)/Win7 Ultimate (x64)
    Thanks for this Shawn.
    Happy Holidays and regards :)
  2. Posts : 72,050
    You're most welcome Lomai.
    I hope you have a great and safe holidays as well. :)
