Chrome GPU Hardware Acceleration - Turn On or Off
    How to Turn GPU "Hardware Acceleration" On or Off in Chrome
    In computing, hardware acceleration is the use of computer hardware to perform some function faster than is possible in software running on the general-purpose CPU. Examples of hardware acceleration include blitting acceleration functionality in graphics processing units (GPUs) and instructions for complex operations in CPUs.
    This tutorial will show you how to turn GPU Hardware Acceleration on or off in Google Chrome browser.
       Tip
    You can revert to original settings by simply following the same steps on this tutorial.
    Here's How:
    1. Open Chrome:
    2. Type "chrome://flags" in the search bar:
    3. Hit enter and it should take you to a page like this. Scroll down till you find "GPU compositing on all pages". Select the option "Default" and change it to "Disabled":
    4. Lastly, click on the "Relaunch now" button to confirm settings:
    That's it :)
  1. Arc
    Another nice addition! Great job
  2. Posts : 71
    Windows 7 Ultimate x64 / Windows 8 Pro x64
    Cool, just another neat thing to know if ya need it!
  3. Posts : 94
    Windows 7 Professional 64 bit
    Select the option "Default" and change it to "Disabled".
    Just to clarify for the OCD folks like me, the steps indicated specifically show how to turn OFF hardware acceleration, and GPU compositing acceleration is the same as Hardware acceleration. And default means Chrome is referencing a flag embedded in the destination site's HTML to force GPU acceleration already for certain sites but that's all negotiated behind the scenes by the browser.
    Do I got it? I'm pretty sure I do, but humor me here and I can sleep better at night knowing for sure
  4. Posts : 1
    Under windows 7 ultimate x64, Google Chrome Version 32.0.1700.107 m
    Hello i tryied the steps but i don't have the option instead i have this :
    GPU compositing on all pages Mac, LinuxUses GPU accelerated compositing on all pages, not just those that include GPU-accelerated layers. #force-compositing-mode-2
    Sorry, this experiment is not available on your platform.
  5. Posts : 1
    Windows 7 Ultimate 32bits
    Sorry for answering so late but I only noticed lately that chrome is taking too much memory and found in Chrome Task Manager a process called GPU that was taking up to 115Mo so I end it and it didn't change anything.
    Trying this tutorial, I found the same message as werr. This was weird as if the GPU is not available, why a related process is running ?
    I tried to contact the developers through the Leave feedback button on the About page but didn't got any answer.
    I finally found this solution that I wanted to share with people which have or will face this problem :
    Just create a shortcut to Chrome and then add to the Target field of the Properties window the following command (separated by a space from the "chrome.exe")
    --disable-gpu
    and that will prevent this process from running.
    If the process keep running, try adding
     --disable-software-rasterizer
    but normally this is not necessary.
    Good navigation with a little lighter Chrome !
