Windows 7: Disk Management - Post a Screen Capture Image
26 Sep 2019   #20
RoWin7
Win 7 Ult 64-bit
Do you know this thread is 6 years old? But yes, your screenshot is good.
2 Weeks Ago   #21
Cast
It's a good presentation to see the disk manager in this tutorial.
Capture Linux OS image using WDS (Windows Deployment Services)
Hello. I have an issue. I want to capture an Linux OS custom image or a fresh one and want to use WDS to complete the job. Could it be done? I know I can use WDS from server to deploy WIN 7 or anyother Win OS to other systems. But can I use the same service to deploy Linux OS to other new...
General Discussion
System Image - Extract Files Using Disk Management
How to Extract Windows 7 System Image Files Using Disk Management When you create a system image, Windows 7 creates a Virtual Hard Disk VHD file that contains all of your files. This will show you how to attach (mount) this VHD file using Disk Management to manually extract and restore...
Tutorials
Disk Management Screen Change
I started with this Disk Management screen dated 052214 which is attached below: I want to recover, format as a single NTFS partition, the System Reserved disk (no letter assigned) at the bottom of the Volume list. I right clicked on the disk and assigned it a letter. Now I have the...
Hardware & Devices
Capture Text from image file
Dear All, Do you know how to capture text from image file or PDF file that were converted from image file? I need to capture it because alot of text over there and i don't want to retype it. Thanks
General Discussion
Video and image capture problems on windows 7 64 bits
Hello, I want to capture screen flow in video or image on windows 7 64 bits system, with NVidia Quadro 600 graphic card (driver is up to date). I use lib vlc for video capture, or "print screen" button for image capture. When I try to capture a fullscreen opengl application, or a QML...
Music, Pictures & Video
Twitter Facebook
