Disk Management - Post a Screen Capture Image
Page 1 of 3 123 LastLast
    How to post an informative screen capture of your Disk Management screen
    How to post a proper screen capture image of your Disk Management screen
    If you are seeking help with Windows 7, you will often be asked to include a screen capture image of your Disk Management screen. A well executed capture of the Disk Management screen means you get accurate advice in the quickest possible time.
    This short tutorial will show you how to do this the easiest way.
    Steps:
    1. Click
    2. Right-click My Computer
    3. Click Manage
    4. From the Computer Management screen that opens, click Disk Management.
    5. This step is the most important. Maximize the Disk Management window so it fills your entire screen. Resize the window components so the status and sizes of the partitions are clearly shown.
    6. Use the in-built Windows Snipping tool to capture and save an image of the Disk Management screen:
    Click , then All Programs, then Accessories, then Snipping Tool.
    7. Upload the saved image with your post by using the paper clip icon.
       Tip
    If you are using 3rd party partition software (e.g. Partition Wizard) to view your disk/partition arrangement, and plan to post a screen capture image of that, then follow the same recommendations in step 5 above
    Regards,
    Golden
  1. Posts : 9,606
    I can't remember how many times I posted snips of Disk Management for various threads & read other senior members doing the same. This will be a good link!
  2. Posts : 19,383
    Thanks Doc!
    Awesomeness!
  4. Posts : 19,383
    Thanks Greg - lets hope its useful.
  5. Posts : 10,994
    Win 7 Pro 64-bit
    Very nice, Colin. This will definitely be a time saver.
  6. Posts : 19,383
    Thanks Lee!
  7. Posts : 24,479
    Windows 7 Ultimate X64 SP1
    This will save us a lot of typing Colin, thanks much!
  8. Posts : 19,383
    Thanks mate!
  9. Posts : 15,026
    Windows 10 Home 64Bit
    Easy and will be used alot :)
    Good work as always!
