Hey Brink,
I just read your tutorial, "How to Change Device Driver and Information Installation Settings in Windows 7 and Windows 8," and I have a question for you:
Which Driver Installation setting do you recommend right after a fresh, reinstallation of Windows?
I just did a clean reinstall of Windows 7 Pro and I'm getting ready to install Windows Updates, and then my system drivers. I changed the Windows Update setting to "Check for updates but let me choose to downlad and install them," but I'm not sure what the best setting is for drivers.
I'd like to see what Windows recommends for driver updates, but I want to choose which ones to install.
I'd appreciate your advice. Thanks.
