Device Installation Settings
Page 3 of 3 FirstFirst 123
  1. Posts : 1,109
    windows 7 professional 64 bit
       #20
    Hello Brink :), got this device installation settings short-cut on my desktop from your ( very good ) instructions.
    I want to myself (manually ) install new drivers for sound and have already for months my updates on "check for updates but let me chose".
    Can I now just go to any manufacturer ( needs to be good with Windows 7 sp 1 home service and my Inspiron laptop ) and install ?
    Will that automatically remove the old ( 2009 ) sound driver ? Hope you get this, it's an old thread from juni 2015.
  2. Posts : 71,977
       #21
    Hello Thelma, :)
    Yes, you could go to your device manufacturer's support website to download the latest driver for that specific model number.
    For Dell Inspiron M501R:
    Product Support | Dell US
  3. Posts : 1,109
       #22
    Thanks a lot Brink :), will have a go tomorrow !
    Cheers,
    Thelma
    PS :Thanks for the link
  4. Posts : 71,977
       #23
    You're most welcome. :)
  5. Posts : 29
    Windows® 7 (64-bit)
       #24
    Does anyone know where the executable is for the Device Installation Settings pop-up being talked about in this thread, the one that asks "Do you want Windows to download driver software etc, etc, etc." as shown in this image :
    can't get the image to show no matter what I do;
    please just take a moment to look here, if you would, thx :
    https://postimg.org/image/6m0r4f81d/
    … so that I can create a shortcut to it and invoke it directly? I know that this pop-up does in fact have its own executable, meaning it isn't necessary to go through Devices and Printers. I have a folder that contains direct shortcuts to quite a few Windows settings like this one, and would like to add this one.
  6. Posts : 71,977
       #25
    Hello GuccizBud, :)
    Do you mean for this below?
    Device Installation Settings Shortcut - Create in Windows
  7. Posts : 29
    Windows® 7 (64-bit)
       #26
    Hello GuccizBud, :)
    So, is there a prize or something for fastest correct answer to a forum post? Because you just won . Yeah, that, lol . . . thx a million my friend, much appreciated.
  8. Posts : 71,977
       #27
  9. Posts : 29
    Windows® 7 (64-bit)
       #28
    Works great, love it. I'll invoke it a few more times to get my fill, then move on to something else .
