Desktop Background - Change
Page 3 of 10 FirstFirst 12345 ... LastLast
  1. Posts : 9
    windows 7
       #20
    Shawn, creating a new administrator account didn't work :/ It just did the same thing
  2. Posts : 72,051
       #21
    Cirux,
    Could you upload (paperclip icon on toolbar while editing post) the image in a ZIP file? I'll test it on my system to see how it works on it to see if it's just the image or something else.
  3. Posts : 9
    windows 7
       #22
    I'm not entirely sure this is the problem though cause I've tried a couple different images but it never seems to work. Thanks for trying so hard to help me though I appreciate it. Oh and this one has a border to fit my screen, the only one I have without it is a little different.
    Desktop Background - Change Attached Files
  4. Posts : 72,051
       #23
    Yeah, it's the image's size. I resized it to where it looks good to me. See how this looks for you.
  5. Posts : 9
    windows 7
       #24
    Well it looks fine, but I attached a screen shot with a different image it's supposed to show up tiled but its not.. I included the actual image so you can see if maybe it is just the images im using. I dont actually want the image tiled, I'd kind of like it centered though, its just to show I dont think my picture position function is working.
  6. Posts : 72,051
       #25
    It works for me set as tiled, but your screenshot looks like it was set as "Stretched" instead.
  7. Posts : 9
    windows 7
       #26
    Ok so I figured it out! I wasn't just going crazy, apparently because it's hp I had to download a driver specifically for the picture position option. Weird :/ Anyway, thanks for all your help Shawn.
  8. Posts : 72,051
       #27
    Ah, I would not have guessed that one either. I'm happy to hear that you got it sorted. Thank you for posting back with this. :)
  9. Posts : 4
    Windows 7 Professional
       #28
    I like the new slideshow capability in Win7, but I did notice a strange behavior:
    - If I have a slideshow set up as the theme, I cannot make the desktop icons disappear using right-click->view->show desktop icons to turn that flag off. It
    does deactivate the desktop icons and it is like they aren't there, and yet they are.
    If I switch it back to a single background to turn off the slideshow, then the capability returns to make the desktop icons disappear and reappear as they are supposed to.
    If I use a 3rd party wallpaper changer like Steve Murphy's AWC, then I get a wallpaper changer plus the "show desktop icons" flag works correctly as well.
  10. Posts : 4
       #29
    Desktop Icon Issue
    The problem with Desktop Icons refusing to vanish is somehow related to the combination of Windows 7 and Windowblinds 7. Stardock is looking into it.
